As per title
6 x S15 Injectors $450 firm. - Tested and cleaned
RB25 G/box with brand new slave cylinder and modified speedo drive for R32. Also still have R33 speedo drive but will need a new pinion gear. Comes with shifter, all shifts nice and smooth $1350
Tailshaft modified for RB25 g/box in R32. $150 OR take the G/Box and tailshaft for $1450
Garret 3071r .82 rear housing. Includes 4" Metal inlet and metal outlet pipes. Also includes braided oil feed and water lines. Crazy turbo, i started seeing boost around 2800 on a RB25!! $1600
RB25 PowerFC w/hand controller. Great condition, all functions working tip-top! $1350
Buddy clud N+ Spec coilovers to suit R32 gts-t. Only 3000km on these and still have over a year manufacture warranty, still have user manual all everything i got with them etc...... don't buy chinese crap, these are quality Jap Coilovers. Perfect for your track/drift street driven car. $1300
Contact me by phone or PM
Mobile : 0422 034 450
Cheers - Ryan
Hey Mate,
Just sent you an sms regarding the Power FC with HC....
Just out of interest, where are you located?
Thanks,
Pete
Edited by Peter
PM sent re:
As per title
Cheers - Ryan
PFC Sold - pending payment..... sold in about 1 minute!!!!
Don't you worry bout dat!
Quickest keyboarder in the West.... :)
How many km's done on turbo? Any room to move on price?
About 2500 - 3000kms done. Never really been pushed. Only got tuned last month and never got around to taking to track so.... honestly.... this turbo has reall never been pushed.
Also, just to answer another common question atm, turbo is still on car so i don't really have any pics now, also on that note, i will need a standard RB25 turbo to replace this with therefore as far as price goes ill take $1350 + a good condition RB25 turbo with lines..... perfect option for anyone upgrading!!!
yep no prob. im gonna try get some pics up tomorrow.
Also, g/box sold, however without the slave cylinder and modified speedo drive were not sold with it and now for sale.
Brand new genuine slave cylinder $80
Modified speedo drive. Drive unit is brand new!! $65
Pics will be up asap.
!!!!!TURBO SOLD!!!!!
I'll see you saturday Ryan.
0433351794
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
