vitz_n1....
Long time overdue but thanks for sending the Power FC through COD!
Top bloke to deal with, package came across extremely fast and was very well packed. Power FC is now up and running in the car - ALL GOOD!
Thanks mate - hope you got your cash?!
Peter
