  • Replies 343
Posted Images
I had no luck at all connectiong last night!
Thought the private match worked perfectly...too bad there was only 2 of us lol
Yeah figured out that the only way for me to play is to join friends sessions....
To bad everyone is like level 40+ and i'm J-U-S-T on level 4....
Sad...
If anybody wants to add... Big_Amph
we had a party of about 4-5 of us last night
There was me
RBPOWA (TRJ86)
omgtr
another mate of mine (mehehe66)
and NateR31 (Natious) came in and out a few times
Big Amph joined my session for a bit later on as well.
Doh i knew i should have gotten on...girlfriend had other ideas though, apparently vampire diaries rates as more important!
There was me
RBPOWA (TRJ86)
omgtr
HAHA, that was you guys!!!
Sorry for bringing the team down, my palty 1-5 kills v 15 deaths...
SAD SAD SAD...
I'll more than likely be playin tonight til late for those on PS3
If I see you on Dezz I'll jump in
I didn't prestige for a while then got bored and thought why not... then immediately regretted it
I struggle to get my kill/death ratio up as I can't stand being in one place for too long and prefer rushing into stupid places blazing away and throwing grenades lol
Bunta: that's why we have another TV/DVD player in the bedroom, and why I download all my wife's favourite shows for her;)
I have decided i am really shit a MW2, i never get kill streaks! I did get harrier strike for the first time the other night but couldnt work out how to use it properly and ended up bombing a big patch of nothing lol
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
