Hi guys, have been having an issue with hesitation or missing.
At first it only happened when the car came on boost hard, it would hesitate badly, not smooth boost delivery, choppy. But this does not happen all the time, sometimes it is fine when it is on boost.
Lately it feels like it is hesitating/missing more just when driving around normally, ie: off boost under a bit of throttle. Again, this does not occur all the time either. Sometimes on idle it feels rough and sounds like its missing, other times it idles fine.
Yesterday, when I started it up it sounded like a WRX for a few minutes, then it went back to sounding normal.
Cant be air flow metres as I run a Vipec which doesnt need them. I have the usual bolt on upgrades; -5s, bigger injectors, fuel rail, fuel pump, cam gears, zorst, etc.
Car had been running like a dream since tune, this problem has just started up in last couple of weeks or so.
Coilpacks are still the stockies, do you rekon this is my problem? Are coilpack issues limited to off boost or on boost or can it be both as per what is happening with my car??
Or what else do you think could be causing my issues?
Thanks people
https://www.sau.com.au/forums/topic/271829-should-i-change-my-coilpacks/
  • Replies 49
most likely wiring or coilpacks. sounds more like coils though. common problem. next time it starts to misfire pull off the leads one at a time and when you pull a lead off and the noise doesn't change you know it's that cylinder. then replace the coil.
have you tried cleaning all the jackets?
you could always upgrade to spitfires but it's not always needed.
how many k's has it done?
does it run fine when you first start driving, but after a little while gets worse. if so i'd say the coils. there is a ghetto mod that some have used to fix it up, but i went the spitfires and it was worth every dollar after being able to floor it through the rev range!
I'd try find someone you can borrow a set off for a few days. Surely someone there in NSW can let you have a borrow of a set for a day or two (and you put yours in thiers)... if yours runs great and thiers suddenly crap then you know for sure
Better than spending $600+ on something that might not even fix the problem.
That said, R34 ignition setup isnt the best, so its fairly likely but still IMO diagnose before spending :D
Also go over all the connections with contact cleaner, you never know, could just be an average connection.
Also what plugs/gap? How long since a service?
Service was only done ~1200 Klms ago. Not sure on the brand of the plugs or the gap but new ones went in when it got tuned ~ a month ago.
Maybe I should put new coils in anyway considering Ive replaced most of the other bolt on stuff with new items??
yeah try plugs and gaps.
Also could be a leak in your plumbing if u aren't running stock BOV's
If it had a leak, should it play up all the time? Sometimes there doesnt seem to be a problem then it comes back.
Maybe 1 of the coils or plugs is working on a part time casual basis.
in my old 180 had the slightest of slightest leak in my plumbing and it would hesitate sometimes and i would get less boost. I tightened all my clamps and tightened BOV. all good afterwards.
You've got a hard pipe kit dont u?
Wouldn't start running like crap and sounding like a WRX when you turn it on at cold start though and then suddenly pick up to perfect. to intermittent for it to be a leak imo. if you have plenty $$ to spend get some new coils and i'm almost certain the problem will be gone.
this may be a silly question,
but have you been switching fuels?? maybe the tune was carried out on a different mix of fuel...
I only use bp ultimate with no probs, vpower on the otherhand was like chopping of the cars' balls!
(last time i used it i noticed the missfiring/hesitation/rought starts...)
Yeah I do switch between fuels but my tuner told me that it would be OK to do so.
Will most likely get new Coilpacks, reading other threads it sounds like the problem came and went for others also until they replaced those.
This morning the car ran pretty good. No hesitation while driving and boosting to 1.2 Bar with no problem. On idle it sounded like it had a few lumps in it but it wasnt a rough shaky idle.
remove coilpack, delicatly place it on a bench and then smash it with a hammer, put coilpack back in.. if problem persists.. get new coilpack, repeat process for each coilpack or until all 6 are royal blue in colour. works everytime. :)
cheers
linton
remove coilpack, delicatly place it on a bench and then smash it with a hammer, put coilpack back in.. if problem persists.. get new coilpack, repeat process for each coilpack or until all 6 are royal blue in colour. works everytime. :banana:
cheers
linton
Nice one hehe!
have you looked at the coils yet man? a friend with a 180 cracked a stock coilpack after raising the boost quite a bit higher; he pulled them out and found a crack in one of the coils so he used some silicone to seal it and it was fine after that.....ps: he put in new ones a week or 2 later.
goodluck man
you did have problems with your injectors before ? were they all replaced?
maybe it is another injector issue. I would get someone to check it out before spending lots of money on parts when you are not sure what the issue actually is.
All the injectors got replaced with brand new items.
I think this problem used to happen from time to time when I first bought the car when it was stock so a coil may have been slowly on the way out back then.
Its an R34 GTR yes, but it is still 10 years old. There are others on this forum with R34 GTRs that have had very similar problems.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
