would also like to add, this is a r34 gtr with low km's. not very old. it would not be suffering from coil pack issues yet.
yes but it is 10 years old, and the engine is making alot more power than the standard engine, and the coilpacks just cant handle it anymore.
  • Replies 49
would it not be worth it to upgrade the coilpacks anyway... they are 10 years old, the engine is making 150kw more than standard... bakes has spent alot of the folding stuff on all this gear... even if they didnt need to be done, it would be a worth while upgrade.
what happens if he swaps some coils for someone else's... and the other person's cant handle the power and break down... then bakes is up for 2 sets of coils instead of one. the only way to rule out the coils is to get new ones.
Bakes
I am having the same issue as you with my car - exactly the same - will occasionally miss on or off load - and yes, sounds exactly like a WRX when started up sometimes.
The problem is pretty intermittent for me - and seemed to resolve itself after I replaced the plugs - then it came back again - but not as frequently or as bad.
I do find that once the car has warmed up a bit it will come good.
I've been pondering the Splitfire coilpacks or one of the HKS ignition kits as a possible solutions.
So let us know how you go on once the coils go in.
Bakes
Seriously man, I have to agree, sounds EXACTLY the same. Ive ordered the Splitfires today, Ill let you know how it goes. Might be able to put them in late next week depending on when they arrive at my door.
HKS use stock rb26 coil packs on the drag car. runs 7's ?
wow - i had no idea...i have a standard set on my gtr & another standard set from my previous aust delivered gtr :(
i guess i wont be upgrading for now if there is no real benefit other than age/wear & tear
I would suggest to try some ones elses coils first. I had a miss firing problem, I tried the coils, didnt fix it, yet I still got charged for them. Anyway, in the end for me it was a leak in the gaskets. Run a smoke test through your valves and see if there are any leaks. Soon as I sorted my gaskets out, the car was so smooth again :(
HKS quite possibly change their coilpacks as often as they do plugs.. which is after 7 seconds.. i have no doubt that the standard coilpacks are capable, when new.. but i think id rather cough up $600 for splitfires than $1500 for a new set of stockies.
where do you get that price from? i had no idea they were that expensive
the only place you can get them from... nissan. last I checked their 26 coils were about $300 each retail. why do you think people buy splitfires when their standard coils fail? it's not for the pretty blue colour that's for sure!
Last time i was at my tuners he said he had a pretty worked 34 gtr on the dyno. It was making ok power but not what everyone expected with the setup it had (I don't know details of setup). He said it wasn't missing/hesitating or anything but they decided to throw a set of split fires in as well as a set of HKS plugs. Straight away the car made 100kw more. He said the same thing as R31Nismoid, that the late model coil setup on 33's and 34's are just shit and he recommended his customers with late model skylines to change them, or keep this in mind, even before the car goes into the workshop. Anyway, my 2c.
well one thing I'd look at is plugs. as you run more power and more boost you need to think about the heatrange plug you are using. for a standard car 6s may be ok. personally even with light upgrades I'd go to 7s and with more boost and different turbos you may even need 8s. my silvia will miss heavily as it ramps onto boost with 7s, but runs amazingly well with a set of 8s in there. I know coppers are cheap and are "ok". i was a big fan of using cheap $3 NGK coppers and changing them a lot. but now having used true high performance Greddy and HKS plugs I can tell you there is a big difference. Since they use irridium tips they can run a very fine 0.6mm tip which is a good thing. high performance car should have high performance plugs.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
