  • Replies 49
Nothing wrong with Nissan coils... R32/R33. Hell i used stock RB25 coils for 370rwkw @ 24psi. I needed a HKS box to go further, that was my only issue.
Splitfires/Nissan - all the same shit anyhow really. Only difference is the price.
I highly doubt the HKS car would be changing coil packs each run though.
Seen many a car here make 380-400rwkw on nissan/splitfires without a HKS DLI!
Once you get into the 400rwkw+ region however the little HKS 'black box' is another key ingredient required... I bet the HKS drag car has a HKS black box :D
Only thing is does the black box decrease the life of the coils? That is something that there seems to be zero information about.
c'mon! don't tease a bloke. I need facts dammit. or at least some well worded lies?! give me somethng.
Can i try to start? :D
The plugs were originally 1.1, and gapped down by hand... in the process the head was damaged on one/two of the plugs!
HKS quite possibly change their coilpacks as often as they do plugs.. which is after 7 seconds.. i have no doubt that the standard coilpacks are capable, when new.. but i think id rather cough up $600 for splitfires than $1500 for a new set of stockies.
i recently back to back tested stocko's vs splitfires, stockso were f**k knows how many genuine km's old out of an r32gtr engine package, punishing both sets of coils on the dyno stock where better, not buy all that much but considering the condition of the stocko's and the splitfires(barely10-15000km's old) i'll never use anything but stock coils again.
splitfires are good on a budget replacement, but dont expect as much out of them as you'll get out of standards
and yes that HKS ignition amplifire is about the only upgrade out there that works successfully for these things
Can i try to start? :)
the plugs were fine.. and so end another episode of "name that failure", thanks for playing.
which one of the 3 types of racing plugs from trust do you prefer?
the greddy irridiums are a good budget-ish plug at around $15 each. and the proper greddy racing plugs are excellent but a bit pricey at $25+ each.
the ones i use in the silvia are these ones 13000078 (T7340T-8) and in the GTR the $$$ racing ones are 13000108 (R7419-T8)
I used to think they were just a wank and was happy enough with the $3 coppers, that is until I actually tried them. :)
yep, healthy stock coils and HKS magic gold box is the way to go if you want fat spark. if your stockies fail and you don't want to spend $1500 on new ones then splitfires are not bad but definitely not an upgrade over stock that's for sure.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
