Hey fellow sau members i just finished with a half cut and have alot parts left ova
of list below
SYDNEY pick up only ... sorry too busy to stuff around with posting stuff
I have most pics i need find my usb cable to add but if interested ill send u a pic asap
FOR SALE
2x front coil overs stand nissan( seem alright ) $30 each
washer bottle with motors $ 30
strut brace r32 front $50
2x r32 N/A floating calipers+brackets $20 each
R32 RB25NA head( is striped cept valves and springs) $200
-178k wear on them
-cams In + ex $ 80
-cam gear in and ex $60
- rocket covers ( painted matt black) no gaskets$100
R32 25NA block not touched after removed-- $200
R32 auto starter motor ( worked when removed) $40
Airconditioning lines + compressors x2 $40 for lot
r32 blinkers lh and rh $ 20 each
r32 head lights lh $40
r32 head light rh cracked at front $ 15 ( if anyone wanted to fix glass)
r32 auto tail shaft - diff to gear box $40 ( no bolts supplied comes as 2 parts)
r32 na exhaust manifold+ heat shield and o2 sensor$ 90
r32 accerater pedal $15
r32 power steering pump+ bracket $40
r32 dash surround behind steering wheel auto (prnd321)$15
r32 alternater $ 40
r32 radiator auto $ 50
r32 toque converter (auto) free( not sure how good it is)
r32 AUTOMATIC transmission FREE to pick up.. input shaft stuffed*( been sitting out side for 9 months
r32 auto seleter $20
r32 blue turbo cluster 94k on speedo $ 90
r32 air flter box parts+ some piping $15
r32 standard front lower control arms $ 40 each require bushes
r32 engine fan rb 25 $ 30
r32 Intake manifold rb25na $90
r32 l/h and r/h engine mounts $50 for both
r32 rb25 na fuel rail and injecter wiring $50
r32 standard pipe manifold too the cat $40
r32 POD filter cover red it came off so it fits $60
r32 2x fan shrouds $15 each
r32 master cylinder $100
r32 brake master cyliner $60
r32 horns x2-$10
PM ME FOR ANY REQUIRES
  • Replies 50
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
