  • Replies 50
Hey fellow sau members i just finished with a half cut and have alot parts left ova
of list below
SYDNEY pick up only ... sorry too busy to stuff around with posting stuff
I have most pics i need find my usb cable to add but if interested ill send u a pic asap
FOR SALE
2x front coil overs stand nissan( seem alright ) $30 each
washer bottle with motors $ 30
strut brace r32 front $50
2x r32 N/A floating calipers+brackets $20 each
R32 RB25NA head( is striped cept valves and springs) $200
-178k wear on them
-cams In + ex $ 80
-cam gear in and ex $60
- rocket covers ( painted matt black) no gaskets$100
R32 25NA block not touched after removed-- $200
R32 auto starter motor ( worked when removed) $40
Airconditioning lines + compressors x2 $40 for lot
r32 blinkers lh and rh $ 20 each
r32 head lights lh $40
r32 head light rh cracked at front $ 15 ( if anyone wanted to fix glass)
r32 auto tail shaft - diff to gear box $40 ( no bolts supplied comes as 2 parts)
r32 na exhaust manifold+ heat shield and o2 sensor$ 90
r32 accerater pedal $15
r32 power steering pump+ bracket $40
r32 dash surround behind steering wheel auto (prnd321)$15
r32 alternater $ 40
r32 radiator auto $ 50
r32 toque converter (auto) free( not sure how good it is)
r32 AUTOMATIC transmission FREE to pick up.. input shaft stuffed*( been sitting out side for 9 months
r32 auto seleter $20
r32 blue turbo cluster 94k on speedo $ 90
r32 air flter box parts+ some piping $15
r32 standard front lower control arms $ 40 each require bushes
r32 engine fan rb 25 $ 30
r32 Intake manifold rb25na $90
r32 l/h and r/h engine mounts $50 for both
r32 rb25 na fuel rail and injecter wiring $50
r32 standard pipe manifold too the cat $40
r32 POD filter cover red it came off so it fits $60
r32 2x fan shrouds $15 each
r32 master cylinder $100
r32 brake master cyliner $60
r32 horns x2-$10
PM ME FOR ANY REQUIRES
Cant pm yet...Im keen on airbox u still have it? im in syd..
hey do u still have the rocker cover screws (u kno all those little screws/small bolts that how the valley cover and the rocker covers down) ill take them if u got em sumwhere
offer on the other stuff left
will take cheap offers for pick up only i need stuff gone in next 2 weeks taking up alot room
manifolds int and ex , wiper motor , throttle body 25na , washer bottle and motors , FREEE AUTO transmission has been rained on, tailshaft 2 piece auto
struts, na/ calipers alot parts from a half cut 32 and a ecr 32 25na
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
