  • Replies 50
Hey fellow sau members i just finished with a half cut and have alot parts left ova
of list below
SYDNEY pick up only ... sorry too busy to stuff around with posting stuff
I have most pics i need find my usb cable to add but if interested ill send u a pic asap
FOR SALE
2x front coil overs stand nissan( seem alright ) $30 each
washer bottle with motors $ 30
strut brace r32 front $50
2x r32 N/A floating calipers+brackets $20 each
R32 RB25NA head( is striped cept valves and springs) $200
-178k wear on them
-cams In + ex $ 80
-cam gear in and ex $60
- rocket covers ( painted matt black) no gaskets$100
R32 25NA block not touched after removed-- $200
R32 auto starter motor ( worked when removed) $40
Airconditioning lines + compressors x2 $40 for lot
r32 blinkers lh and rh $ 20 each
r32 head lights lh $40
r32 head light rh cracked at front $ 15 ( if anyone wanted to fix glass)
r32 auto tail shaft - diff to gear box $40 ( no bolts supplied comes as 2 parts)
r32 na exhaust manifold+ heat shield and o2 sensor$ 90
r32 accerater pedal $15
r32 power steering pump+ bracket $40
r32 dash surround behind steering wheel auto (prnd321)$15
r32 alternater $ 40
r32 radiator auto $ 50
r32 toque converter (auto) free( not sure how good it is)
r32 AUTOMATIC transmission FREE to pick up.. input shaft stuffed*( been sitting out side for 9 months
r32 auto seleter $20
r32 blue turbo cluster 94k on speedo $ 90
r32 air flter box parts+ some piping $15
r32 standard front lower control arms $ 40 each require bushes
r32 engine fan rb 25 $ 30
r32 Intake manifold rb25na $90
r32 l/h and r/h engine mounts $50 for both
r32 rb25 na fuel rail and injecter wiring $50
r32 standard pipe manifold too the cat $40
r32 POD filter cover red it came off so it fits $60
r32 2x fan shrouds $15 each
r32 master cylinder $100
r32 brake master cyliner $60
r32 horns x2-$10
PM ME FOR ANY REQUIRES
Cant pm yet...Im keen on airbox u still have it? im in syd..
hey do u still have the rocker cover screws (u kno all those little screws/small bolts that how the valley cover and the rocker covers down) ill take them if u got em sumwhere
offer on the other stuff left
will take cheap offers for pick up only i need stuff gone in next 2 weeks taking up alot room
manifolds int and ex , wiper motor , throttle body 25na , washer bottle and motors , FREEE AUTO transmission has been rained on, tailshaft 2 piece auto
struts, na/ calipers alot parts from a half cut 32 and a ecr 32 25na
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
    • Is the jack stand system tied into the cage somehow? Upgrades look goooood 😍
    • Big updates, tons of work and $$$
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
