25GTV Posted May 26, 2009 Share Posted May 26, 2009 Hey guys drove a mates r34 na the other day... Compared to mine (both stock) his car seemed to be a little slow (flat spot) between 4300rpm and 5400rpm then it seemed to have some punch after that... Any ideas why? Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/ Share on other sites More sharing options...
iseekool Posted May 26, 2009 Share Posted May 26, 2009 The variable length manifold could be sticking.... Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4618533 Share on other sites More sharing options...
Mr.Massive Posted May 27, 2009 Share Posted May 27, 2009 manual or auto?? Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4619189 Share on other sites More sharing options...
maike Posted June 7, 2009 Share Posted June 7, 2009 The variable length manifold could be sticking.... how would you know if the maniifold was sticking? and how would you fix this? I have this same problem. have a auto. unless this is normal on the auto Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4641752 Share on other sites More sharing options...
resh Posted June 7, 2009 Share Posted June 7, 2009 Can definitely say this isn't normal on auto's as my auto really begins to open up from 3k onwards (no flat spots at all) and I'm also stock (other than spitfires and iridium plugs). Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4642572 Share on other sites More sharing options...
666DAN Posted June 9, 2009 Share Posted June 9, 2009 The variable length manifold could be sticking.... +1 Has someone recently fitted a pod filter to the car and just blocked the line that runs from the control solenoid on the butterfly valve? (actuator between the dual entry) This line must go to the intake as when it opens it needs flowing air, blocking it prevents the butterfly from opening up. Most people accidentally do that when they remove the air box, as that's where the line goes, they just plug it...big no-no and loses you massive amounts of power. Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4644903 Share on other sites More sharing options...
iseekool Posted June 9, 2009 Share Posted June 9, 2009 Assuming the lines are connected - make sure the actuator assembly is also well lubricated and that there are no leaks on the diaphram or hose. Also a good time to check the fuel filter too. Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4645049 Share on other sites More sharing options...
N-DAWG Posted June 9, 2009 Share Posted June 9, 2009 hmmm interesting reading this as since having my turbo conversion done i've been noticing a flat spot in the mid range. Sometimes I'll be around 2-3k revs in 2nd or 3rd (tiptronic auto) and WOT just sort of struggles? It's like it wants to up n go but can't until it gets to around 4-5k. I thought maybe it's just the characteristics of this set up, or just the auto transmission isn't getting the power down well enough in the mid-range. Now I just thought this valve was controlled electronically based on revs, didn't realise it was controlled by vacuum lines. Since reading this thread I've decided to check the online R34 workshop manual http://www.scribd.com/doc/5332929/Nissan-S...-Manual-English to see how the vacuum lines run. On page 15 of the navigation on that link, I followed the vacuum lines from the canister to where it meets the first hard line, and also done the same for the airbox vacuum line, and then compared it to how it is on my car. The result is that they're switched around at the first pair of hard lines. Basically what appears to be the hard line that leads to the variable intake solenoid is getting a vacuum signal from where the airbox used to be. The line isn't plugged though just tucked away. Now it seems to me that this seems to be the reason I'm having a midrange flat spot. Could be the same case for the OP? Would there any reason why my vacuum lines are being run this way or is it more than likely human error in reconnecting them? More to the point, given that it's been tuned the way it is, would reconnecting the vacuum lines to match what is in the workshop manual cause me any issues with the tune? Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4645745 Share on other sites More sharing options...
_bobo_ Posted June 9, 2009 Share Posted June 9, 2009 think this is the problem i mioght have..r33 n/a auto... happens usually around 60km/hr i notice tho struggles and slows for a bit then goes back to normal anyone show pics on what to do/ to fix? thanks Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4646323 Share on other sites More sharing options...
iseekool Posted June 11, 2009 Share Posted June 11, 2009 think this is the problem i mioght have..r33 n/a auto...happens usually around 60km/hr i notice tho struggles and slows for a bit then goes back to normal anyone show pics on what to do/ to fix? thanks I'm assuming you are on light throttle? If that is the case - it is due to the car being too high in gear (4th) and the torque converter locking - to help save fuel. The reason the the car then feels "normal" afterward is because the ECU/TCU detects the engine is "struggling" so to speak, therefore it releases the tourque converter lock and lets the trans slip in 4th or will down shift to 3rd. Do you feel the engine has problems reving up smoothly? Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4649561 Share on other sites More sharing options...
_bobo_ Posted June 11, 2009 Share Posted June 11, 2009 I'm assuming you are on light throttle? If that is the case - it is due to the car being too high in gear (4th) and the torque converter locking - to help save fuel. The reason the the car then feels "normal" afterward is because the ECU/TCU detects the engine is "struggling" so to speak, therefore it releases the tourque converter lock and lets the trans slip in 4th or will down shift to 3rd. Do you feel the engine has problems reving up smoothly? Usually not full throttle medium-had throttle it sometimes happens, speed just dies down a bit then goes bak up( not when changing gears but while its revving through out it)..and not usually in a high gear but say if i use 1 2 D on gear shift. Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4650577 Share on other sites More sharing options...
dori34 Posted June 11, 2009 Share Posted June 11, 2009 i think i had this problem on mine before (manual r34) i didnt take much notice as i was thinking it was the spark plugs getting old and needed a change. we'll see in a week time when it comes out if its gone. Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4650627 Share on other sites More sharing options...
666DAN Posted June 14, 2009 Share Posted June 14, 2009 Kinda right, it is triggered by the output from the ECU, it uses the same pin as the GTt which triggers the boost solenoid from low to hi boost. In the 25GT it controls the actuator for opening up the intake, but when it actuates it pulls air through that hose. If the hose is blocked it forms a vacuum sucking against nothing, so doesn't open up. That hose needs to go to atmospheric for the actuator to fully function. so you need two things -Signal from the ECU telling it to open (can wire 12v directly to it and it's open 24/7) -hose going to air intake, no obstruction so the valve can open, on a turbo car pick it up from the pressure side. hmmm interesting reading this as since having my turbo conversion done i've been noticing a flat spot in the mid range. Sometimes I'll be around 2-3k revs in 2nd or 3rd (tiptronic auto) and WOT just sort of struggles? It's like it wants to up n go but can't until it gets to around 4-5k. I thought maybe it's just the characteristics of this set up, or just the auto transmission isn't getting the power down well enough in the mid-range.Now I just thought this valve was controlled electronically based on revs, didn't realise it was controlled by vacuum lines. Since reading this thread I've decided to check the online R34 workshop manual http://www.scribd.com/doc/5332929/Nissan-S...-Manual-English to see how the vacuum lines run. On page 15 of the navigation on that link, I followed the vacuum lines from the canister to where it meets the first hard line, and also done the same for the airbox vacuum line, and then compared it to how it is on my car. The result is that they're switched around at the first pair of hard lines. Basically what appears to be the hard line that leads to the variable intake solenoid is getting a vacuum signal from where the airbox used to be. The line isn't plugged though just tucked away. Now it seems to me that this seems to be the reason I'm having a midrange flat spot. Could be the same case for the OP? Would there any reason why my vacuum lines are being run this way or is it more than likely human error in reconnecting them? More to the point, given that it's been tuned the way it is, would reconnecting the vacuum lines to match what is in the workshop manual cause me any issues with the tune? Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4655284 Share on other sites More sharing options...
25GTV Posted June 14, 2009 Author Share Posted June 14, 2009 Problem found... Hoses for the varible intake butterfly were on the wrong way... one comes from the soloniod one is from the vacumn tank... All fixed now Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4655315 Share on other sites More sharing options...
666DAN Posted June 14, 2009 Share Posted June 14, 2009 Yey for the forum...imagine the trouble I had with this 7 years ago, I had one of 10 R34's in the country :S Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4655397 Share on other sites More sharing options...
LUME Posted June 20, 2009 Share Posted June 20, 2009 mine doesnt open up and run good unless im at 5800 theres nothing below that, 7k in second speedo's sitting on 115 :S Link to comment https://www.sau.com.au/forums/topic/271853-midrange-flat-spot/#findComment-4668504 Share on other sites More sharing options...
