Blue 1990 S13 Onevia
Reg'd until March 2010
Body Work:
Blue/ Purple pearl paintwork
Black bonnet raised at the rear for airflow
Black Shaved boot lid
Type x 180sx side skirts
Custom one off rear pods
"Freedom Parts Project" front bar with genuine type x 180sx front parkers and indicators
Hand flared rear quarter guards
shaved aerial hole
Suspension/Brakes
Fully adjustable coilover suspension (very firm ride)
(Shock body and spring seat adjustment)
Front: Kei Office struts with camber tops
Rear: JIC Struts
S15 5 stud conversion (brand new 7/4/09 front hubs with bearings have receipt)
S15 rear subframe and diff
Cusco front strut brace
Custom rear strut brace
Custom brake master cylinder stopper
S14 wheels with hankook rubber
Engine/Driveline
Clean SR20det (Oil stays clear colour for many km's after oil change) and runs very smoothly.
S14 5 speed gearbox
Heavy duty cushion button clutch
Yashio Factory twin core radiator
13inch Thermo Fan mounted inside factory radiator shroud, with in cabin factory switch (whilst retaining factory engine fan)
Trust Airinx pod filter ( i will include stock airbox with k&n panel filter)
Z32 Air flow meter
Custom Stainless intake pipe
S14 jap spec T28 with HKS Actuator
R32 GTR Intercooler
Heat wrapped exhaust manifold
3inch front pipe
3 inch hi flow cat
3 inch stainless steel cat back
Electronics/Interior
GTR fuel pump
Greddy Emanage Computer with Injector control harness and air fuel control harness tuned for maximum safety by Protek.
Greddy Profec electronic boost controller set to 12psi
Greddy white face Boost Gauge
Greddy white face Water temp gauge
Tomei air fuel ratio gauge (not hooked up)
Omori exhaust temp gauge (not hooked up)
Momo steering wheel
S14 front seats
Aircon and Sound deadening has been removed
JVC Headunit (not installed and no speakers)
The car comes with Victorian VASS certificate and is registered until late March 2010
I can "assist" a buyer with RWC. (the main things are pod and too low, i have an aibox and the susp is adjustable)
Price; $10,500 ono with s14 wheels.
Now $10,000 with s14 wheels MAKE A REASONABLE OFFER, IT MUST SELL SOON!
or
$12,000 with meisters.
will consider swaps but not after modified car.
Located in Vic.
speedo is inaccurate, due to s15 rear diff upgrade, I will include a Jaycar electronic speedo correction kit for the buyer.
this car is well cared for, has been garaged since i imported it late 2005...
car is also advertised on carsales:
http://www.carsales.com.au/all-cars/privat...id=11ECB169BD5D
thanks,
greg-
Here are some up to date pictures... thanks for looking.
it's not that far. in fact I bought my silvia in melbourne. it's a good chance to fly down, pick-up car, then enjoy one of the nice vic race tracks and then drive it back. :) seems like pretty good value to me too.
That's true, but I had a mate who bought his car from ACT and drove it back and have heard nothing but negative comments when it comes to transfering the rego to NSW via RTA :(~
If someone can convince my differently then I may fly down :D
i'm not familiar with nsw rta,
a friend of mine recently bought a VW bora from nsw, when it arrived in melbourne he took it to vicroads with a rwc and the reg transfer form and that was it.
it would be worth checking with the rta to see if the fact that the car is an import will subject it to more scrutiny...
the vass certificate that comes with the car may or may not be relevant in nsw, but the car is already registered so it "shouldn't" be an issue.
thanks,
greg
That's true, but I had a mate who bought his car from ACT and drove it back and have heard nothing but negative comments when it comes to transfering the rego to NSW via RTA :)~
If someone can convince my differently then I may fly down :woot:
Have you ever heard anything but negative comments about NSW RTA????
Queens Birthday Price Drop
$9500 with s14 wheels
$11,500 with work meisters.
First in best dressed.
call me to arrange a viewing over the weekend.
0401 873 739
Greg-
  • 3 weeks later...
Deposit has been taken, so the car is sold pending full payment...
looks like it's heading across Bass Straight!
Yeah my mate is buying her she looks and sounds like a sweet drive.
tassie here she comes.
Edited by 0siris
    • Yeah was gonna say as it wouldn't line up correctly, I imagine if they put the wheel that way it would mess with the wheel alignment.
    • My Neo turbo only went last year. Not 35 years old, to be sure - closer to 25. But still.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
