Hey all, i want to correct the rear camber on my R33 and ive heard bushes are the way to go so ive found a whiteline kit on ebay.
Its not a very good picture but theres just eight plastic bushes and 4 metal sleeves (Whiteline Part # KCA347)
So, questions i have are;
1. It claims +/- 0.75 deg, that confuses me pretty good as it seems like nothing, how do i know if its enough? :s
2. Its up for $150 delivered, does that sound right?
3. Seeing as theres not many parts it seems pretty simple but how hard are they to fit and adjust?
4. Does anyone know a better option or where i can get a better price?
Edited by Joe_89
https://www.sau.com.au/forums/topic/271917-camber-correction-kit/
do a search, there is a company that sell the arms that give +- 4 camber on the back. Not sure about the front.
i think that part number refers to the rear bushes. U also gotta factor in that u must get these pressed in, not cheap unless u r really strong :P
Depends on how bad the camber is too. If its only a tiny bit -u can flip the tyres, but if u got alot might be worth investing.
Although normally the skyline has alot worse camber on the back, so check that first!! its just the car
That is normal price for the bushes, check whiteline's website.
Yea i heard the arms arent as good as bushes (need adjusting regularly and they crack and break), didnt know they had to be pressed, what do the bushes get pressed into? :s
And does anyone know where i could take my car and just have it done my them? (brisbane area)
bushes wont give you as much adjustment as upper or lower control arms will.
When I just had my bushes in my r33 - I think I had -1.5 or so at the rear and -1.9 up front.
This was also due to the car being slightly lower.
I had a mod done with the front, I had the front cross members modified so I had -4 up front...bt that was used for track :D
How low is your car? ifits too low, that can be an issue with getting too much neg camber.
give fulcrum suspension a call.
They do superpro bushes and kits etc for skylines
decent prices and they can install and wheel align etc.
Thanks, ill go down there and see what they come up with ay.
Its got standard suspension with "low" king springs, think thats about a 50mm drop? not sure though
How much camber has it got now? The kit will remove 0.75 degrees plus the standard camber adjuster is good for another 0.25 degrees.
If you haven't had the camber checked then the guidlines are simple, all measurements are centre of wheel to guard of course;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
OK price, but not great.
The process is simple, remove the upper control arms and traction rods from the car. Put them in a press, around 10 tonnes is enough, so a small home garage style will do it. Push out the old non adjustable rubber bushes and press in the new adjustable polyurethane ones. Stick arms back in the car and take for a wheel alignment. Make sure the aligner has experience in Skylines as they have to adjust the traction rods and upper control arms in tandem otherwise you will end up with bad bump steer.
Yes
Cheers
Gary
Yes
Cheers
Gary
Thanks for that gary, but now im just plain CONFUSED haha. I just went out and measured from the centre of the wheel to the guard and got; Rear: 475mm and Front: 485 so your measurements suggest my car sits 105mm higher than standard but i have camber suggesting the opposite? :P (top of the wheel sits in, inner tyre wear)
Oh and if you could post up or PM deails about a better option and or price id appreciate it :D
Thanks for that gary, but now im just plain CONFUSED haha. I just went out and measured from the centre of the wheel to the guard and got; Rear: 475mm and Front: 485 so your measurements suggest my car sits 105mm higher than standard but i have camber suggesting the opposite? :( (top of the wheel sits in, inner tyre wear)
u measured wrong, ive had 400mm before and it was stupidly high, possibly either didnt measure it right, or u misread (375 and 385)
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
