R34 clutch fairs much better than the R33 item.... remmeber the r34 and r33 have TOTALLY different clutches... also the car would slip after a few pulls which is why we stopped chasing results.
haha I bought my car withy 118,000 on it 2 years ago (car was dead stock except japo 17" wheels), clutch feels stock, not heavy, can ride it, seems so stockish but held up to over 340RWKW's and on low boost, still 320kw's its still going strong. this is in my 33 gtst.sorta looking forward to when in runs out so i can see what the hell it is
Edited by Mr. Untouchable
  • Replies 55
whats this about stock clutches only handling so much power!? could someone please elaborate? mine is a "heavy duty" on the receipt from a clutch shop, but has a heavy pedal and a more forgiving release point than my mates who run the exedy single plate 'drift' clutches.
something doesnt add up
your making 241rwkw by 14psi on the standard clutch??????????????????????????
either something is wrong or you dont have a standard clutch
my stock clutch couldnt handle 185rwkw and died
i dont know of anyone who has gone over 200rwkw with stock clutch
not saying its impossible, but i am VERY surprised to hear you say stock clutch still ?????
for the record, stock spec clutch holding 203kws here, and hopefully more later on!
mine went at about 180rwkw... got an exedy cushion button from slide, 300 bucks for the install, couldnt be happier... so far she hasent slipped yet..
very comfy, if you are looking for clutches atm
Have had my standard clutch pushing 185rwkw for almost 4 years now. The clutch looked very new though, got it with the gearbox that came in my halfcut and the clutch had definitely not done 75,000k's... more like 5000, if that.
It's just started to slip, going with a Exedy sports organic (32GTR push type) since I'm putting on a bigger turbo.
I use to think my clutch was stock too (got the car at 60,000ks)... peddle was relatively light etc etc. That was until I jumped into my friends car and realized how much heavier my pressure plate really was. Still started to die at 180kw.... was destroyed once got 200+
WOW those injectors are HUGE for that power!!!
Hows that printout coming along?
yeah, bit of a touchy subject, they were bought from a fellow sauer and are not real flash, real poor spray pattern at idle...... they are the old siemens type. Shame as the rest of the car is mint, we are working out a solution atm.
hmmm, turns out the only thing I thought I didn't upgrade when it was changed (the clutch) was upgraded...
Not a stock spec clutch but an Exedy heavy duty clutch as I just found out... after driving it for 2+ years ;)
240 rwkw on a compliance cat ?!@ wow. Did you happen to check your exhaust BP ? Be some power hiding in there hopefully, once clutch is fixxed.
Gary
this also seems to be bit of a myth (for later compliance cats anyway), maybe to sell cats? i see alot of cheap aftermarket cats being not much better than the later compliance cats...
maybe a bit off topic but im in the middle of installing this turbo into my r33 and im having trouble in finding a hose to run from the standard bov into my custom made intake pipe aparently they dont make the size and there stiff so hard if you get twists what have you guys done to get out of this.
Just finshed my install of this turbo on my r33 and im very happy with it, besides the design of the dump being clamped on by a O ring whcih leaked everywhere the turbo it self it performing quite well also ill add that im running stock ecu and only running about 12 psi stock fuel pump it has a lil bit more lag but once u hit boost it goes and skates everywhere great turbo guys for a half the price of a gt3076 or 3071.
Yeah the hypergear v clamps are shit, get a decent clamp and it will be sweet.
errrrr its not 100% on the clamp. You can get stronger clamps but Its just made to hold, It can't seal up gaps.
Its when you weld the dump pipe into the O ring. They don't expand in the same sort of rate. So on the end the flat surface of the O ring becomes buckled under pressure as it cools down.
Normally to weld the O ring you need to divide it into small sections wait it cools down before moving on to next, Or machine the O ring flange flat before fitting it in the car.
pics of install please!!!
plus how did the install go?!? all easy apart from the the dump... have you got pics of what went wrong with the dump?
errrrr its not 100% on the clamp. Its just made to hold, It can't seal up gaps.
we have roughly angle grinded a mismatched v-band surface (HKS have a lip on them, Garrett don't) and used a HKS clamp to hold surfaces tightly together and it has held on for about 6 months now with no leaking holding 440rwhp!!!
so it might be the clamp :blink:
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
