the install went alright you need to trim the manifold heat shield, extend you cooler pipe make up and intake pipe and oil line is given and water lines blocked up and the dump pipe in regards to it buckling i put the extension inside the o ring and spot welded around it so was no buckling because its matches up perfect with the Oring on the turbo and dump it just doenst seal ive put sum exhuast sealant and a gasket and its worked fine. but the turbo itself is great a few minor things to modify but worth it rather than paying 4000 for a direct bolt
  • Replies 55
sounds good!
can you please put up some pics when you get time?!?
sounds good!
Here are the pics for you if you have any other specific photos of the install you want just ask
how the turbo fit in note the actuator realy close to the body so bracket had to be changed so it would come to the middle abit more also exxhust manifold heat shield trimmed
size of the turbo
custom cooler pipe 2inch to 2.5inch going from turbo to stock cooler pipe
how the cooler pipe extension sat
roughly how it would look like when put together prety well hidden
intake pipe made up used a 90degree silicon elbow from the turbo then this 45 degree offcut clamped onto the elbow
can you spot the boost controoler LOL
how it looks in the end now
Edited by skline01999
errrrr its not 100% on the clamp. You can get stronger clamps but Its just made to hold, It can't seal up gaps.
Its when you weld the dump pipe into the O ring. They don't expand in the same sort of rate. So on the end the flat surface of the O ring becomes buckled under pressure as it cools down.
Normally to weld the O ring you need to divide it into small sections wait it cools down before moving on to next, Or machine the O ring flange flat before fitting it in the car.
i checked them both and they were 100% flat and true, we swap out the supplied clamps and the problem goes away.....
looks good man. do you have a pic with everything put back on (heat shield etc.)
does it look sorta stock?
I havnt put the turbo heat shielf bak on cause its kinda hard to fit it in theres not much room espiacly with the acutaor and all you would prob have to modify the origanal one cutting it down alot and bolting it to the exhust manifold heat shield but yeah apart from that looks stock espcially with stock airbox
nice pics, thanks for that!
do u have any of the dump pipe installed?!?
you should be able to get a v-clamp to suit from most turbo stores
just want to confirm the spec of turbo you used was it a TR43i with internal gate with 31mm hole? maybe hypergear can confirm?
Ill try get you a pic of the dump pipe installed but you basically get a 2.75inch Oring which you end up welding to your existing dumpipe then clamp it on. yeah its tr43I 500hp turbo IW and i think its 29mm
will be very interested to see well it holds/controls boost
plus how responsive and what power it makes, when u getting it tuned?
Well im losing my lincese in a few weeks so im gona save up do the injectors pump and afm then get remap ecu at dr drift and tuned. so ye a while
I managed to get my heat shield back on by bending it a little. I tried to take some pics but my camera is not playing nice at the moment.
Mine is going back to Status next week, getting the clutch and a new map done for my mammoth injectors so I will hopefully be pushing the high 200's then. I'll keep you all posted.
  • 3 weeks later...
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
