the install went alright you need to trim the manifold heat shield, extend you cooler pipe make up and intake pipe and oil line is given and water lines blocked up and the dump pipe in regards to it buckling i put the extension inside the o ring and spot welded around it so was no buckling because its matches up perfect with the Oring on the turbo and dump it just doenst seal ive put sum exhuast sealant and a gasket and its worked fine. but the turbo itself is great a few minor things to modify but worth it rather than paying 4000 for a direct bolt
  • Replies 55
sounds good!
can you please put up some pics when you get time?!?
sounds good!
Here are the pics for you if you have any other specific photos of the install you want just ask
how the turbo fit in note the actuator realy close to the body so bracket had to be changed so it would come to the middle abit more also exxhust manifold heat shield trimmed
size of the turbo
custom cooler pipe 2inch to 2.5inch going from turbo to stock cooler pipe
how the cooler pipe extension sat
roughly how it would look like when put together prety well hidden
intake pipe made up used a 90degree silicon elbow from the turbo then this 45 degree offcut clamped onto the elbow
can you spot the boost controoler LOL
how it looks in the end now
Edited by skline01999
errrrr its not 100% on the clamp. You can get stronger clamps but Its just made to hold, It can't seal up gaps.
Its when you weld the dump pipe into the O ring. They don't expand in the same sort of rate. So on the end the flat surface of the O ring becomes buckled under pressure as it cools down.
Normally to weld the O ring you need to divide it into small sections wait it cools down before moving on to next, Or machine the O ring flange flat before fitting it in the car.
i checked them both and they were 100% flat and true, we swap out the supplied clamps and the problem goes away.....
looks good man. do you have a pic with everything put back on (heat shield etc.)
does it look sorta stock?
I havnt put the turbo heat shielf bak on cause its kinda hard to fit it in theres not much room espiacly with the acutaor and all you would prob have to modify the origanal one cutting it down alot and bolting it to the exhust manifold heat shield but yeah apart from that looks stock espcially with stock airbox
nice pics, thanks for that!
do u have any of the dump pipe installed?!?
you should be able to get a v-clamp to suit from most turbo stores
just want to confirm the spec of turbo you used was it a TR43i with internal gate with 31mm hole? maybe hypergear can confirm?
Ill try get you a pic of the dump pipe installed but you basically get a 2.75inch Oring which you end up welding to your existing dumpipe then clamp it on. yeah its tr43I 500hp turbo IW and i think its 29mm
will be very interested to see well it holds/controls boost
plus how responsive and what power it makes, when u getting it tuned?
Well im losing my lincese in a few weeks so im gona save up do the injectors pump and afm then get remap ecu at dr drift and tuned. so ye a while
I managed to get my heat shield back on by bending it a little. I tried to take some pics but my camera is not playing nice at the moment.
Mine is going back to Status next week, getting the clutch and a new map done for my mammoth injectors so I will hopefully be pushing the high 200's then. I'll keep you all posted.
  • 3 weeks later...
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
