Hey guys I have a 94 R33 gts-t auto and loving it and wanna change the coils ,as one is definately playing up, problem is its definatly a ser 1 R33 but seems to have ser 2 engine/ignition maybe swaped by previuos owner,
anyway how can i be sure? there is definatly no ignitor located on in near or around the coil loom, I have followed it back down the harness so I was thinking that if someone could post comfirmed ser1 or ser2 coil pic i could see which is mine ive searched this a bit now but nothing seems to get confirmed. I have learned from all my reading that im getting spiltfires Im lovin this forum cheers
https://www.sau.com.au/forums/topic/272008-confused-as-to-which-coils-to-get/
Wow, that was quick. Front facing intake? Makes it a WHOLE lot easier. It's kinda hard to tell for me, but they look like series 1's to me. Pretty blurry pics though, and I've only seen series II a couple times before, so I'd wait on confirmation from somebody else. Have you though about trying to repair them? Their are several write ups, but the two main ways are a insulative coating and cleaning out the brass/aluminum contact under the boot/spring with a dremel or some sand paper or something. Try both :(
yea its just a std R33 with intercooler. I want the better coils just for piece of mind just a coincidence one failed today. hopefully i find out tonight so i can airbag some. cant belevie the mark up on these things loclaly $1150.00 fitted :(
It's not hard to "refurb" the coils if you want to just give that a shot, and they do go out ALL the time. Pull the little rubber boot off the bottom, twist the spring out careully as not to bend it (not that it really matters unless you really bugger it up). The stick a dremel or something down in there to clean out the crude until you see shiny metal. Might want to hit the top of the spring with the stone too. After you get it all back together, put several coats of "flexane" or something similar like silicone sealant or liquid electrical tape on the outside of the coil to help stop it from arching.
man i type slow 2 replies will im repling hehe
ok definatly there is no ignitor present the coil harness ends into a plug then diaapears I have seen the pics of ignitors on this forum so im clear i no what im looking for
sounds like engine was swapped just need sumone to say yep that is a ser 2 coil and im laughing
I'm bettin S1 but you need to answer my question to know for sure.
:) ok we all agree
1. the pic are really shit
2.3hole on coil is s2
3.Car is a 1994 ser1 R33 auto running ser 2 parts
4. those pics where really shit
Thanks for the help guys im thinking of going supa sparks based on feed back in the forum is there any real reason for getting splitfires if not seems like im paying for a brand not a product. the extra cash could go towards tyres :/
:) ok we all agree
Get some yellow jackets coil packs and save even more money towards better tyres :D
Performance-wise has them on his site for about $380/set - www.performance-wise.com
Ive had a set of yellow jackets in my car for about 5 months now and they havent skipped a beat.
Plus they come with a 12 month warranty and wont melt like the super spark or JJR ones have been known to do.
Edited by d_liberate
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
