Hey guys, on my car i rev out to 7000 RPM i was wondering if i could change that to 8,500? I know my rb25de wont handle it but what can i do to make it handle it? just forge the shit out of it? I'm not 100% sure how it works, can anyone please help me?
Edited by nizmo da gizmo
https://www.sau.com.au/forums/topic/272034-rev-limiter/
first off why, if your doin it for sound buy a exhaust
but if you want to do it:
valves + valve springs
rocker arm stopers
lighter pistons
stronger rods
etc etc
plus you might want to upgrade cooling (bigger radiator)
https://www.sau.com.au/forums/topic/272034-rev-limiter/#findComment-4641527
I think the 25det bottom end is reliable to around 7500rpm, lightweight pistons will reduce the pull on the rods giving you a few hundred more rpm. The stock cams will rev that high, but will be way out of their power range, so you will need some higher duration shafts, 270's ought to do it.... You may have issues with valve float, so to be safe you might want new valve springs. Past 8000rpm, esp with cams and increased lift, your going to have issues with the hydrolic lifters, which is something you don't want, do you will need to convert them to solids. If you are revving to 8500, it would be wise to balence the crank, fit new bearings, a higher flowing oil pump, some thinner oil, billet flywheel and aftermarket balancer, as well as under drive pulleys on all your accessories... You will encounter breathing issues with your cams and higher rpm, so twin throttle body's might be a good idea, or a front facing bell mouthed plenum (jun style, should feed them higher revs nicely) and 80mm throttle OR at least a 68mm XF jobby.
quite an expensive excersize. Alternatively, you could drop an RB26DETT head straight on it, sfa modification (head studs, you lose vct, and will have to weld an RB26 header plate on your extractors - which you will need to purchase, but is definately you bang for buck, as it contains the cams, valve springs, ITB's (throttle flow) and lifters you require. On an N/A you might be able to getaway with another 1000rpm to standard, I'm not really sure what 25 bottom ends are good for, its not like you would be putting a lot of power down. With the 26 head there is no reason you couldn't run all the 25 gear.
An RB25DE Mines ECU should have the limiter removed, or at least raised a lot, i know i never found the limiter on my mines ecu, but was never game to take it past 7400rpm (adjusted cam timing with aftermarket 256deg cams took me there) also any form of full aftermarket management will let you move or remove the limiter.
OR forgetting all of the above, if you are just after rice points (which is fair enough, each to their own :P) fit a mandrel bent 2" exhaust system (it can flow enough for a stocker 25de don't you worry) with a mandrel center offset muffler or 2 (pending req'd volume) AND NO CANNON, then simply fit an aftermarket tacho (or modify the stock one) to work in 4 or 5cyl mode, you will see your glorious high rpm, and your car will sound like it is screaming.
:D
https://www.sau.com.au/forums/topic/272034-rev-limiter/#findComment-4647567
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
