Other cheap options include Adaptronic and the Nistune stuff. Both are good options and will do eveything you need it to. The Adaptronic also has autotune like Motec systems and multiple trigger options including the optical Nissan sensor. Nistune are like a PowerFC without a couple of the bells and whistles but with all the mapping adjustability you could want.
https://www.sau.com.au/forums/topic/272043-power-fc/page/4/#findComment-4649023
  • Replies 62
I was kind of suspicious when I looked at their site and the LT-10S was recommended for 4 cylinder cars - If I'd known what these ECU's were prone to being like before buying the car I'd have gotten another one!
I know that I have to send the ECU back to Microtech to get something changed in it to run VCT, and I have tried to contact them in the past and look on their forum RE my ATTESSA issue, but I've only got one car so it's kind of hard to just pull the ECU out and leave it sitting there for weeks on end. I am also heartily sick of driving a car which gets ~270km to a full tank, even though RB25's can be kinda thirsty, that's ridiculous for only having a KKR 480 and being driven on the highway mostly!
Depending on the wiring (which I'm pretty sure is still mostly the RB20 stuff since it runs the RB20 igniter etc), I'm leaning more towards Nistune; my mates reckon remaps are just as good, but I guess that the tuner I end up going to can elaborate more on that.
Whilst the PowerFC is popular amongst import owning friends, as well as the remap, I find the price of a RB25DET PowerFC + Z32 AFM to be kind of prohibitive, and I am also sceptical about the real 'need' for one in a car that is only mildly modded.
On the good side of the Microtech though, the display is handy, and has warning lights for max injector duty, overboosting and a shift light, and I can monitor injector pulse, coolant temp, volts, boost and RPM with it, and when I had overboosting problems when trying to set up my Profec A boost controller, and cooler pipes slipping off, it cut (ignition I think?), which although scary is better than a blown motor!
https://www.sau.com.au/forums/topic/272043-power-fc/page/4/#findComment-4649485
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
