hey all, im a little stumped as to what type of amp i should use to run 2 x 12" type s that i just got.
i really dont know jack about car audio so i need some advice.
they are 200rms, 4ohm, single voice coil model.
am i going to either have to (1) run 2 monoblock amps bridged or (2) run a 2 channel amp
or do i have any other options.
im not exactly rolling in the funds much these days so a cheaper option would be better.
https://www.sau.com.au/forums/topic/272050-what-type-of-amp-should-i-run/
You only need one monoblock or a bridgeable 2-channel amp that is 2 ohm stable. You would run your 2 subs in parallel, therefor the amp will see a 2ohm load.
From here it depends on your budget. But you would want at least 500wrms to be safe (it's better to over power then under power)
Alpine monoblock (MRP-M500) - $499 and puts out 500wrms @ 2 ohm
A cheaper option would be a Jaycar responce amp $349 and will provide 380wrms per sub (these amps are meant to be great value for money)
hope this helps
Edited by -Stokesy-
cheers for that. i was never aware that if i connect the 2 subs together then i could use a 2 ohm load on the amp.
also had another member send me though a link on how to wire it that was very usefull for me aswell.
http://akamaipix.crutchfield.com/ca/learni..._4-ohm_mono.jpg
i think i might have a look at the jaycar, ive heard some good remarks about it and the price is definetly good.
jaycar prices are definetly good for the fact that the gear is pretty cheap crap (to be honest) i would recomend more likely to go something like some clarion or pionner speakers or sumthing if u want sumthing cheap and allright quality, but if u want something decent u can pick up a nice set of boston speakers (BOSTON being speaker speciallist) for about $250 for a set of splits and they will be better quality (sound and build) then the jaycar equipment. but thats just my 2 cents.
He's after an amp, not speakers.
PDX amps are great, especially when you're tight on space. They are expensive though, so he may want to consider something else a bit lower in the price range. Plus it might be just me but i would consider PDX amps to be a bit over the top for a type s sub
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
