Hi Guys
This is a "evolution" of an old post - sold stuff has been taken off, prices have been updated and some more stuff added. I will add photos as I find them.
Engine parts:
R33 RB26 Block - Standard 05U
Standard 86mm bore size
Will need "tunnel bore" as cradle is off another block
$300
R33 RB26 Block - 05U
87mm Preped by ADVAN (stamped into block)
Turbo oil feed has been re-enforced
Has crack around one head stud
Came out of running car
(I bought this off another forum member apparently can still be used - but I havent investigated any further)
$250
RB26 Standard Rods
Good Condition
Ideal Upgrade for RB25 apparently?
$150 set
RB26 Standard Rods
Good Condition
Fitted with ARP Studs
$200 set
Adjustable Cam Gears
Suit RB20 / RB26
Inlet and Exhaust
$150 pair
Adjustable cam gears
(exhaust just cnc slotted)
$120 pair
Stock Cam Gears
RB26
$50 pair
RB26 Sump With Diff
Came off R33 (suits R32 as well)
$450
Rebuilt R33 GTR Turbos
New Bearings and Seals
360 degree thrusts
N1 Exhaust Turbine
Never Used
$POA Arriving Soon
(pic)
GTR Group A Turbos
Modified Housing
Fully Rebuilt
Came of a car prepped by Mines
Available soon
$POA
Suspension parts:
Cusco Pillowball Tops
Suit BNR32
Suit many types of suspension
As is
$150 set
(pic)
Cusco F Upper Control Arms
Suit BNR32
Stronger and allow more neg than stock arms / good upgrade for worn stock arms
$POA Available soon
ELECTRONICS
Z32 80mm AFM's x 2
$450 pair or $500 with plugs
Japaneses Chip for R32 GTR ECU
Fujitsaki SPL (?)
Chip Only
Have used this chip and it works well on our fuel and 18psi
$80
Stock GTR ECU
Missing top and bottom lid (not as pictured)
(I put them on my power FC...)
$150
IMPUL ECU
Suit R32 and R33 GTR
Good upgrade if you are running intake and exhaust mods
Good AFR's
$250
(pic)
R32 GTR Gauges
Three Gauge Cluster from centre console
$100
JDM "LMOO" Oil Pressure Gauge
Mechanical includes braided line
$50
R32 GTR Body Parts
Nismo style sideskirts
Rear Section only
(fit up / over factory skirts)
$150 pair
Trust style read pods
$150 pair
or both Nismo skirts and trust posds for $250 the lot
WHEELS
Technomagnesio
Magnesium alloy 5 spoke rim
17 x 9 +25 (suit GTR32)
Just been Stripped
can powdercoat in your choice of colour
$POA Available soon
Rays TE37
17x8 / 17x9
GTS-T offset ( +30 ish)
Just Been Stripped
can powdercoat in your choic of colour
$POA Available soon
17" Tyres
255/40 hankooks (?)
70%
$150 pair
17" Tyres
255/40 Yokohama Advans
70%
$200 pair
Stock R32 GTR Airbox
$150
Dual 140mm Apexi Power Intake Filters
Suit GTR with 80mm AFM's
$120 for the pair
(pic)
Stock GTR Intercooler
$200
(pic)
ARC Intercooler
Sut R32 and R33 GTR
(R34 with small mod)
$1250
EXHAUST
Stock RB26 Dump Pipes
$50 pair
NISMO cat back exhaust
R34 GTR
Stainless 80mm piping
Very good condition
2pce can be shipped
$500
SEATS
Bride GIAS "Style" Seat
Exactly like GIAS / Low Max seat
Just doesnt say bride anywhere
$500 each (2 seats only)
Open to offers on some stuff - other stuff I 'm not
No lowballers please. Available for pickup in melbourne or will ship at buyers expense.
PM or email me [email protected]
Edited by Antimatter
  • Replies 40
Hi Guys
Thanks for the interst thus far - FYI I have listed the R34 GTR exhaust and the Advan Block on ebay (starting at 99c!) - auction ends sunday 7th of June.
Cheers
Hey, very interested in the cusco strut tops, what condition are the bearings in? Could they be easyly enough replaced?
How much would shipping to perth be you think?
Interested in 1 AFM - are you willing to separate? Also, they should work on a r33 GTST?
Suit RB20 / RB26
Inlet and Exhaust
$150 pair
Are the blue cam gears new or used???
Hi guys
Cam gears are new - after 2k for the Group A turbos
Cheers
Steve
Suit RB20 / RB26
Inlet and Exhaust
$150 pair
Guys
Thanks for all the messages - FYI:
Z32's And Apexi Filters SOLD pending payment (Harry)
Air Box on hold pending payment (petra)
Cusco tops SOLD pending payment (BNR#@)
Nismo Skirts and Pods SOLD pending payment
Cheers
Steve
pm sent
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
