Assorted Genuine And Aftermarket Gtr / Rb26 Parts, Engine Parts, R32 Body Parts, Nismo R34 Gtr Exhaust Wheels And Lots More
Hi Guys
This is a "evolution" of an old post - sold stuff has been taken off, prices have been updated and some more stuff added. I will add photos as I find them.
Engine parts:
R33 RB26 Block - Standard 05U
Standard 86mm bore size
Will need "tunnel bore" as cradle is off another block
$300
R33 RB26 Block - 05U
87mm Preped by ADVAN (stamped into block)
Turbo oil feed has been re-enforced
Has crack around one head stud
Came out of running car
(I bought this off another forum member apparently can still be used - but I havent investigated any further)
$250
RB26 Standard Rods
Good Condition
Ideal Upgrade for RB25 apparently?
$150 set
RB26 Standard Rods
Good Condition
Fitted with ARP Studs
$200 set
Adjustable Cam Gears
Suit RB20 / RB26
Inlet and Exhaust
$150 pair
Adjustable cam gears
(exhaust just cnc slotted)
$120 pair
Stock Cam Gears
RB26
$50 pair
RB26 Sump With Diff
Came off R33 (suits R32 as well)
$450
Rebuilt R33 GTR Turbos
New Bearings and Seals
360 degree thrusts
N1 Exhaust Turbine
Never Used
$POA Arriving Soon
(pic)
GTR Group A Turbos
Modified Housing
Fully Rebuilt
Came of a car prepped by Mines
Available soon
$POA
Suspension parts:
Cusco Pillowball Tops
Suit BNR32
Suit many types of suspension
As is
$150 set
(pic)
Cusco F Upper Control Arms
Suit BNR32
Stronger and allow more neg than stock arms / good upgrade for worn stock arms
$POA Available soon
ELECTRONICS
Z32 80mm AFM's x 2
$450 pair or $500 with plugs
Japaneses Chip for R32 GTR ECU
Fujitsaki SPL (?)
Chip Only
Have used this chip and it works well on our fuel and 18psi
$80
Stock GTR ECU
Missing top and bottom lid (not as pictured)
(I put them on my power FC...)
$150
IMPUL ECU
Suit R32 and R33 GTR
Good upgrade if you are running intake and exhaust mods
Good AFR's
$250
(pic)
R32 GTR Gauges
Three Gauge Cluster from centre console
$100
JDM "LMOO" Oil Pressure Gauge
Mechanical includes braided line
$50
R32 GTR Body Parts
Nismo style sideskirts
Rear Section only
(fit up / over factory skirts)
$150 pair
Trust style read pods
$150 pair
or both Nismo skirts and trust posds for $250 the lot
WHEELS
Technomagnesio
Magnesium alloy 5 spoke rim
17 x 9 +25 (suit GTR32)
Just been Stripped
can powdercoat in your choice of colour
$POA Available soon
Rays TE37
17x8 / 17x9
GTS-T offset ( +30 ish)
Just Been Stripped
can powdercoat in your choic of colour
$POA Available soon
17" Tyres
255/40 hankooks (?)
70%
$150 pair
17" Tyres
255/40 Yokohama Advans
70%
$200 pair
Stock R32 GTR Airbox
$150
Dual 140mm Apexi Power Intake Filters
Suit GTR with 80mm AFM's
$120 for the pair
(pic)
Stock GTR Intercooler
$200
(pic)
ARC Intercooler
Sut R32 and R33 GTR
(R34 with small mod)
$1250
EXHAUST
Stock RB26 Dump Pipes
$50 pair
NISMO cat back exhaust
R34 GTR
Stainless 80mm piping
Very good condition
2pce can be shipped
$500
SEATS
Bride GIAS "Style" Seat
Exactly like GIAS / Low Max seat
Just doesnt say bride anywhere
$500 each (2 seats only)
Open to offers on some stuff - other stuff I 'm not
No lowballers please. Available for pickup in melbourne or will ship at buyers expense.
PM or email me [email protected]
Edited by Antimatter
  • Replies 40
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
