Nissan Skyline GTR 1990 Silver
Engine has done 16000km
$24000 ono
Ph: 0417 069 478
I bought this car with the intention of keeping it for a long time hence all of the work that has been done to it but I am now moving overseas so I have to sell it. All of the modifications have been made with quality taking priority over cost. The engine was built and tuned by a workshop with a proven history in race car preparation and the suspension and brake modifications produce a quick, brilliant handling car that is liveable for every day driving. The car is currently making 290rwkw on 14psi, it can handle a lot more boost and hence make a lot more power with the forged internals but a boost controller would be needed to make more boost which I have not yet fitted as it makes plenty of power in its current tune.
Most of the parts listed were fitted to the car new in the last 18 months. The ECU has a lot more functionality than I am using including anti-lag, traction control, launch control, etc without a need for any more sensors or anything that it hasn't already got.
I have done one track day in the car but it has never been on the drag strip.
Engine-
-Autronic SM4 ECU
-Forged Wiseco pistons
-Eagle H beam conrods
-Piston and conrod sets balanced
-Balanced R33 crank
-N1 oil pump
-Enlarged oil galleries
-ARP Head Studs
-Tomei 260/252 cams
-Adjustable cam gears
-Gates cambelt
-Oversized valves
-Ported and polished head
-Port matched manifolds
-550cc injectors
-dual feed fuel rail
-Garrett GT2860 ball bearing turbos
-Heat coated Exhaust manifolds
-Heat coated turbo exhaust housings
-3inch split dump pipes
-3 inch exhaust system
-Hi flow catalytic converter
-Pod filters
-6.5kg flywheel
-Heavy duty clutch
-52mm aluminum radiator
-Oil cooler
-Oil cooler sandwich plate with thermostat control
-Braided oil lines
-Walbro fuel pump
-Silicone hose kit (all radiator and heater hoses replaced with silicone)
-Genuine Nissan gasket set
-New engine mounts
Suspension/Brakes-
-Bilstein shocks
-Adjustable Castor Rods
-Adjustable front upper arms (Camber adjustment)
-Adjustable rear upper arms (Camber Adjustment)
-HICAS lock
-Front and rear strut braces
-RDA slotted rotors
-Front and rear calipers serviced
-17x9 Desmond Regamaster Evo wheels
-Maxxis MA-Z1s with 85% read
Other-
-Python Alarm with keyless entry
-Kenwood Stereo
-Torque Split Controller
-Rear LSD
-Nardi Steering wheel
-New drive shaft boots
-New rear cradle bushes
Thanks for looking,
Karl
https://www.sau.com.au/forums/topic/272055-r32-gtr-1990/
$24000 ono
Ph: 0417 069 478
Engine-
-Autronic SM4 ECU
-Balanced R33 crank
-N1 oil pump
-ARP Head Studs
-Tomei 260/252 cams
-Gates cambelt
-Oversized valves
-550cc injectors
-Pod filters
-6.5kg flywheel
-Heavy duty clutch
-Oil cooler
-Braided oil lines
-Walbro fuel pump
-New engine mounts
Suspension/Brakes-
-Bilstein shocks
-HICAS lock
-RDA slotted rotors
Other-
-Kenwood Stereo
-Rear LSD
Thanks for looking,
Karl
mate is it still for sale or sold?
https://www.sau.com.au/forums/topic/272055-r32-gtr-1990/#findComment-4669233
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
    • I initially was going to do the whole car with a block then realised, it would be a bigger monster of the job 😂 I guess that's all part of the learning process. I appreciate all that advice, I think I got a good idea on how to tackle this whole job.
    • I admire your efforts with the scuff pad.  As a mere mortal, I use this for the baulk of my sanding work- https://sydneytools.com.au/product/milwaukee-m18bos125-0-18v-li-ion-cordless-125mm-5-random-orbital-sander-skin-only Yes you can easily create a low spot while sanding. There are 2 types of filler, 1 part of 2 part. The 2 part filler will get used for large corrections and the 1 part filler will get used for pin holes and areas that only need slight filling.  Depending on how zealous you are with the sander (very easy to do with a power tool) or if you are chasing rust etc, yes those low spots will need to get filled or you will end up with a very obvious defects in the paint.  Using the guide coat and large sanding block, high and low areas will be revealed (watch youtube videos for a good visual on this). Its up to you if you think its worth the effort to make the car completely flat before you spray it (you make it flat by filling the low areas).  At the end of the day, it comes down to time. The end result comes from the level of prep put in to the car. If you want a perfect result, you have to put in the time during the prep stage or else it will be impossible to achieve a perfect result during the spraying process.
