Hi all,
I got a bit of a weird problem with my alarm on my car, the car battery has been playing up recently (have radio running for 20 mins (no subs or amps) and battery goes flat).
Over the past few days i will be woken up at about 2:30 - 3:00am in the morning to my alarm going off :rofl: after going to investigate (car is in a locked garage) their is nothing wrong, the sensor light outside isn't even on, so no one is out their, i disarm, rearm then it's fine.
It is a Laserline alarm with ultrasonic sensors and shock sensors, it is not the stupid cat either, cause its never set it off, could this be related to the dodgy battery?
I have replaced the battery this morning so i will see what happens tonight - only happens at night!!!
Also been noticing while having headlights on and reving enging the lights would go a little brighter, i think the cars electrical sys is a little dodgy cause also now the interior light - which used to come on when alarm disarmed, just flashes on and off!!!!
Anyone help, with suggections, etc..?
Kris
https://www.sau.com.au/forums/topic/27208-weird-problems-alarm/
Yes, I'd suggest it's the dodgy battery.
Every time I disconnect the battery on my car, I have to turn the siren off. And if I have a problem starting, the low battery will also cause the siren to sound.
well, it happened again!!!!!!!
The alarm went off at 12:30 this morning, it went off then stopped then about 2 minutes later it wqent off again, nothing was out there again, so i have no idea what is going on. I had to disarm the alarm and leave it disarmed!!!!
can anyone help, or should i take it to an alarm place?
cheers
Kris
Well took it to an alarm place, the Ultra Sonic sensors were to sensative, last night, i had a good sleep without the alarm going off! ;)
Only problem is that, the interior light does not stay on for about 15 seconds as it used to when disarming the alarm, i asked the alarm guy and he said after calling laserline, they told him that when the alarm is disarmed, there is only a switched voltage sent to the interior light, then the interior light delay then should take over, he said my interior light delay must be stuffed in my car,
Do skylines have these if so where would i expect to find it.
Thanks in advance
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
