hey guys as title suggests im looking to get a turbo upgrade for R34 GTT (tiptronic) but not willing to part with the autobox just yet.
just wanna keep it simple, currently have these installed:
FMIC, turbo back exhaust, pod filter. (considering getting MV automatics shift kit as well).
pardon the begginer as i have done research for a long time on this forum (forced induction thread) for quite awhile but just dont seem to get it thoroughly, just a simple straighforward question, what turbo (e.g garett/hks etc) can i possibly put into the car? or its just not possible for an auto to hold up a bigger turbo.
thanks
https://www.sau.com.au/forums/topic/272085-suggestions-for-upgrade/
if you have a spare $1800 lying around you can beef up your box to handle 500hp,
Do you know if this price would apply to an r33 auto, im looking at getting rid of the manual and going auto, trying to get around 300rwkw so that box would be perfect.
correct
RVO Automatics Dandenong, i am getting a service done there saturday morning
whilst to date we haven't seen someone smash an auto box in a skyline, im sure they aren't rock solid units
the issue when you upgrade everything is the autobox takes more torque and typically harsher changes
if you upgrade the ECU to an aftermarket ECU it assumes the car is manual, so it wont "talk" to the auto box to say hey im about change gears
so it may result in flaring on gearchange and delays / harsh gear changes. this in turn puts lots of stress on the auto box
this is amplified when you put a shift kit on the auto box as well, so be careful
by all means do it, just find out how much its going to cost if you shag the auto box
i mean its like all of us, no one expects to replace their gearbox etc (i dont)
but we're always wary of the auto boxes
All good advice Paul but I don't think your standard computer actually does much communicating with your gearbox computer in stock form. What does the engine ECU actually send/recieve from the gbox ecu that an aftermarket, say Powerfc, wont' do? The only thing I can think of is perhaps closed loop running at idle and cruise.
My experience is with the more basic autos but perhaps with the tiptronic stuff it's different?
I know with my extremely basic (but custom) auto trans in the Pulsar the ECU retards timing on gear changes, which is something a PowerFC cannot do. If you have a read Apexi recommend not using a PowerFC in an auto car.
the ECU doesn't exactly speak to the auto ECU but it has logic programming into the mapping so that it knows when the auto box will change gears
this allows the mapping to have retarded ignition timing during gear change.
otherwise without that logic (the auto / gear change logic) the ecu keeps the ignition timing nailed
you can replicate this by using a manual GTST ecu, in an auto skyline.
the ecu just runs along ignition timing normal, and the auto box changes gears.
the end result is the there is no ignition retard on gearchange.
the main difference, is the manual ECU, expects the user will engage the clutch (which means no load on the box) whilst changing gears
this means the load axis drops to 0 and ther3e is no engine load to hurt the box
the apexi powerfc along with most other (in fact all) aftermarket ecus for the skyline are
they are manual ECU's only, that is, they have no knowledge, or care for an automatic gearbox
so in their code and mappings, they dont' cater or work around the auto box
so the timing wont change during gear change. this is the same for any aftermarket ecu you can think of
there is one difference (always is)
an auto powerfc does exist! - but its for toyota only
this is because the auto logic for the toyota is done by a seperate box, whereas nissan is inside the main ECU
so the auto powerfc is able to control the auto box normally and map the gear change stuff etc
there is a lot of logic to auto box control, if you check the manual for the JXZ100 PFC youll see the auto screens, there are HEAPS
literally heaps of settings and pages for auto box control, ie (its pretty complicated)
so - if you change the ECU in an auto skyline, as juliette eluded too, it wont back off timing during gear change
the apexi documentation (and most aftermarket ecu docuemtnation) state for manual use only
for that exact reason - no logic for automatic boxes
mainly because - its lots of code, lots of work, lots of logic, and lots of messing around for a small % of the market - ie; why bother will the effort for a small amount of customers
Vl turbos - are different, they have a mechnical auto box, so they dont need timing back offs, they do something different (not sure what, not sure why, go read calaisturbo to find out)
but the jatco boxes work differently, and can work around the manual only ECU issue (from memory)
the best recommendation, by far for automatic skyline users is
to get a remapped ECU, which retains the standard automatic gearbox logic
be careful with a shift kit, whilst good, and it makes it change quicker
it makes it harsher on the autobox. see if you can find a workshop
who has done some work on auto skylines (or even vl turbos)
they would know LOTS about auto gearboxes, and might even know of some common tricks between the skyline / vl boxes
i was told by a tuner that because i have triptonic gearbox.
if i get a whole new ECU i lose the option of triptonic, but where as a piggy back unit is a better option for triptonics.
as far as i know the gearbox has its own logic. changes when the rev's and speed match up.
e.g: two parrallel lines (RPM/KMPH).... slighty angled towards each other, eventually they meet, and when they do its a gear change. or somthing like that.
just trying to remember what i was told thats all
sounds right, so the best solution, is you keep the stock ecu and piggyback another ECU on top, or remap the stocker
piggybacking another ECU on top is expensive, and a complex exercise ($$$$) in custom work
remap is by far easier, quicker and cheaper
this is a good discussion as i have a r34 gtt thats auto, and have done months of research from reading as many things as i can find about the autobox. but what i found out is that heat and poor maintenance is the big killer and that a shift kit helps pro-long the life of the auto because it puts less stress on the bands and in turn means less heat being made. so now im confused as to whats true. damn the internet and all its info :) .
guys i work at rvo automatics in dande.
if anyone wants any info let me know what you want to know. i'll speak to the boss and reply back.
his been in the game for over 20 yrs, worlds first 1000hp (4L60E, commodore box), and just recently broke
fastest 4 speed auto in aus record (9.80 @ 140m/h), and now going for fastest 6speed auto like next w/e in w.a.
knows his stuff.
alternativly, any one looking for auto work done give me a buzz on 97945004, open tomorrow from 8.30am.
haha only cause i told ryan i'd be in then lol.
p.s i know i shouldn't "advertise". but just fyi i guess
knows his stuff.
owned :action-smiley-069:
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
    • House of Fatz dry dock needs a clean sadly one of the long time stables is leaving this weekend   see ya mr purple
    • Hence why I've only modified my car into a pure daily. Everything has to remain reliable & roadworthy, while providing value and grin factor. It also must not be handcrafted to the extent that the car will be immovable if something breaks because you cannot get or make a replacement to at least limp around with.
    • Nah, I definitely do that kind of stuff with my car. I do drive it around as a daily! It's just that mindset about building a car to actually still use/retain it's function as a car is rare. If you modify your car into a weekender, IMO you've ruined 5/7ths of the fun. It should remain fun to do daily errands in.
