ok heres how the story goes. ive got 2 bosch 044 pump feeding off a 4lt surge tank. they lead off to twin -8 lines then aare joined into one at a -8 y piece i then have -8 all the way to the front with an inline filter (earls screen type) which then joins onto another y piece then to twin -6 lines to each side of the rail.... hardline all the way till i reach the -6 area. now the problem is wen i have both pumps running i have this very strange like choof choof choof noise coming from sumwhere its very hard to locate as the pumps are so loud but as soon as i switch it back to one pump the noise goes away. im very worried that the pumps are fighting each other or sumthin at the y pieces or there is sumthin goin on with fuel pulsation or sumthin because i dont have a damper like the factory cars do. has neone had a similiar problem or neone know how i could resolve this issue?
https://www.sau.com.au/forums/topic/272119-twin-bosch-044-strange-noises/
maybe. idealy if you have two 8mm lines going in to one line you would want that single line to be bigger? perfect setup would be two seperate lines? how much power are you making? is two necessary? maybe get one pump to supply it all? nismo?
just a thought... that noise is not heaps of fuel pouring through your surge tank overflow pipe? one pump would not be chucking as much fuel back in to your main tank?
i will be in the vacinity of 600hp maby more i could probably have run one pump but i wanted to run 2 just to have the extra bit there if its needed... on 1/2line should be plenty enough to do the job.... if it comes down to it im just gonna have to put in 2 3/8 lines. just means ive wasted alot of money on y fittings....
and no it wouldnt be the fuel pushing itself back into the surge its a 4lt surge so its gots plenty of juice to circulate.
i never said fuel pumping back in to the surge. talking about fuel pourng from the surge in to the main tank... if you have wayy too much fuel coming up from the lifter pump and too much fuel pressure going down the line then the overflow pipe will be chucking it back in the main tank... maybe you should check it out.
i'm having a wild guess but it's all i can think off ?
Edited by GT-RZ
well yeh of course its gonna be puting fuel back into the main tank thats a given but for sum weird reason it makes the noises alos near the y fittings..... as if the colliding fuel is causing the noise..... im considering just runing one pump and leaving it at that for now and if i start running out of fuel lata which no doubt i probably will ill run another line and get the other pump working hopefully...... its just a very strange thing
  • Like 1
if you are using a Vi-PEC you can program it to turn on the other pump at higher rpm or boost.
yes but wats the difference if its still gonna do the same thing..... ive been thinking and i thought maby the return back to the main tank isnt large enough to cope with the fuel flow coming in and out and maby its putting pressure into the surge tank which intail would be putting pressure on the wrong side of the fuel pump aswell..... just a thought....
im running the same setup with an 044 lift pump & 2 044's to my dual entry fuel rail.
what ive done is use the existing 'in' & 'return' lines as my 2 'in' lines & ive ran a new return line (as recommended by rips nz)
this should alleviate your problem & its an easy fix
HAHA Youre using a 044 as a lift pump? Thats just stupid. Why? It will just heat the crap out of the fuel and cause major issues. I would use a specific lift type pump instead. haha.
Back on topic, it seems really silly to have 2 of everything then just joining it in the middle...im just day dreaming here but wouldnt this be the same scenario as a tuned length exhaust?
If the 2 pipes arent the same length it causes bad resonation and loss of power. In your case the choof choof choof maybe. Just guessing. I would run 1 -06 line from each of the pumps and put them into each end of the rail. Then to reg from middle of the rail and back to the tank from there. Simplest and easiest way IMO.
these were my thoughts as i wanted to run the factory pump as a lift (seems over engineered this way TBO) BUT when i spoke to jim @ crd he said "stick with the 044, much more reliable"...i think he knows his stuff
2x 044 pumps running continuously on a street car is a dumb idea. First off there are very few regulators that will return enough fuel back to the tank without causing a restiction; hence increasing fuel pressure. Then there is the additional heating of the fuel. If you must have a surge tank than at least switch one of the pumps on when you think it will be needed but dont forget to put a oneway vavle in front of both pumps.
Ohh 044 as a lift pumps is shit idea - dont care who said it.
Edited by rob82
2 pumps... No one way valve...
When you turn one pump off, you do realise fuel flows BACKWARDS through the second pump right?
In much the same fashion if one pump dies, it'll send fuel backwards out the dead pump, leaning your engine out?
Very VERY bad idea for a fuel setup...
Get ONE main pump. If it dies, at least the engine just turns off... It doesn't lean out.
Ive seen this one before...
Fuel temperature. How hot are your pumps when they get noisy. Running two pumps circulates a lot of fuel and its all getting nicely heated up by cooling your fuel rail down. Check them when they are noisy. Warm is ok, but leaning towards hot certainly isnt. They start to cavitate as they boil the fuel internally. Then the sound like they are pumping gravel. The solution is to put a fuel cooler (small tranny cooler) on your return line at the back of the car. It makes your tune far more stable as well and lowers your over all fuel temps and minimises temp variations.
Also, if its an R33 Vspec or R34 gtr there is a fuel pump control module mounted under the drivers side parcel tray. There are two signal wires sent from the ECU that change the factory pump from low speed operation to high speed operation. This happens automatically at a specific load point around 3500-4000 rpm from memory. If you want to run one pump constantly, and switch in a second pump under high load, this is where you pickup the relay activation signal from. That combined with a 1 way valve on the switched pump would do the job just fine.
I see MBS206's point about a lean out, but I believe that a car tuned to the point where it has a need for twin 600hp pumps would also have a decent AFR system as well. Plus if you know your car you can feel when its running lean and if you have 1/2 a brain you dont try and drive through the "flat spot" that it feels like. You get off the throttle and make a few checks.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
