ok heres how the story goes. ive got 2 bosch 044 pump feeding off a 4lt surge tank. they lead off to twin -8 lines then aare joined into one at a -8 y piece i then have -8 all the way to the front with an inline filter (earls screen type) which then joins onto another y piece then to twin -6 lines to each side of the rail.... hardline all the way till i reach the -6 area. now the problem is wen i have both pumps running i have this very strange like choof choof choof noise coming from sumwhere its very hard to locate as the pumps are so loud but as soon as i switch it back to one pump the noise goes away. im very worried that the pumps are fighting each other or sumthin at the y pieces or there is sumthin goin on with fuel pulsation or sumthin because i dont have a damper like the factory cars do. has neone had a similiar problem or neone know how i could resolve this issue?
https://www.sau.com.au/forums/topic/272119-twin-bosch-044-strange-noises/
maybe. idealy if you have two 8mm lines going in to one line you would want that single line to be bigger? perfect setup would be two seperate lines? how much power are you making? is two necessary? maybe get one pump to supply it all? nismo?
just a thought... that noise is not heaps of fuel pouring through your surge tank overflow pipe? one pump would not be chucking as much fuel back in to your main tank?
i will be in the vacinity of 600hp maby more i could probably have run one pump but i wanted to run 2 just to have the extra bit there if its needed... on 1/2line should be plenty enough to do the job.... if it comes down to it im just gonna have to put in 2 3/8 lines. just means ive wasted alot of money on y fittings....
and no it wouldnt be the fuel pushing itself back into the surge its a 4lt surge so its gots plenty of juice to circulate.
i never said fuel pumping back in to the surge. talking about fuel pourng from the surge in to the main tank... if you have wayy too much fuel coming up from the lifter pump and too much fuel pressure going down the line then the overflow pipe will be chucking it back in the main tank... maybe you should check it out.
i'm having a wild guess but it's all i can think off ?
Edited by GT-RZ
well yeh of course its gonna be puting fuel back into the main tank thats a given but for sum weird reason it makes the noises alos near the y fittings..... as if the colliding fuel is causing the noise..... im considering just runing one pump and leaving it at that for now and if i start running out of fuel lata which no doubt i probably will ill run another line and get the other pump working hopefully...... its just a very strange thing
  • Like 1
if you are using a Vi-PEC you can program it to turn on the other pump at higher rpm or boost.
yes but wats the difference if its still gonna do the same thing..... ive been thinking and i thought maby the return back to the main tank isnt large enough to cope with the fuel flow coming in and out and maby its putting pressure into the surge tank which intail would be putting pressure on the wrong side of the fuel pump aswell..... just a thought....
im running the same setup with an 044 lift pump & 2 044's to my dual entry fuel rail.
what ive done is use the existing 'in' & 'return' lines as my 2 'in' lines & ive ran a new return line (as recommended by rips nz)
this should alleviate your problem & its an easy fix
HAHA Youre using a 044 as a lift pump? Thats just stupid. Why? It will just heat the crap out of the fuel and cause major issues. I would use a specific lift type pump instead. haha.
Back on topic, it seems really silly to have 2 of everything then just joining it in the middle...im just day dreaming here but wouldnt this be the same scenario as a tuned length exhaust?
If the 2 pipes arent the same length it causes bad resonation and loss of power. In your case the choof choof choof maybe. Just guessing. I would run 1 -06 line from each of the pumps and put them into each end of the rail. Then to reg from middle of the rail and back to the tank from there. Simplest and easiest way IMO.
these were my thoughts as i wanted to run the factory pump as a lift (seems over engineered this way TBO) BUT when i spoke to jim @ crd he said "stick with the 044, much more reliable"...i think he knows his stuff
2x 044 pumps running continuously on a street car is a dumb idea. First off there are very few regulators that will return enough fuel back to the tank without causing a restiction; hence increasing fuel pressure. Then there is the additional heating of the fuel. If you must have a surge tank than at least switch one of the pumps on when you think it will be needed but dont forget to put a oneway vavle in front of both pumps.
Ohh 044 as a lift pumps is shit idea - dont care who said it.
Edited by rob82
2 pumps... No one way valve...
When you turn one pump off, you do realise fuel flows BACKWARDS through the second pump right?
In much the same fashion if one pump dies, it'll send fuel backwards out the dead pump, leaning your engine out?
Very VERY bad idea for a fuel setup...
Get ONE main pump. If it dies, at least the engine just turns off... It doesn't lean out.
Ive seen this one before...
Fuel temperature. How hot are your pumps when they get noisy. Running two pumps circulates a lot of fuel and its all getting nicely heated up by cooling your fuel rail down. Check them when they are noisy. Warm is ok, but leaning towards hot certainly isnt. They start to cavitate as they boil the fuel internally. Then the sound like they are pumping gravel. The solution is to put a fuel cooler (small tranny cooler) on your return line at the back of the car. It makes your tune far more stable as well and lowers your over all fuel temps and minimises temp variations.
Also, if its an R33 Vspec or R34 gtr there is a fuel pump control module mounted under the drivers side parcel tray. There are two signal wires sent from the ECU that change the factory pump from low speed operation to high speed operation. This happens automatically at a specific load point around 3500-4000 rpm from memory. If you want to run one pump constantly, and switch in a second pump under high load, this is where you pickup the relay activation signal from. That combined with a 1 way valve on the switched pump would do the job just fine.
I see MBS206's point about a lean out, but I believe that a car tuned to the point where it has a need for twin 600hp pumps would also have a decent AFR system as well. Plus if you know your car you can feel when its running lean and if you have 1/2 a brain you dont try and drive through the "flat spot" that it feels like. You get off the throttle and make a few checks.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
