Lol where would i get one of them from though? I dont mind cutting the trim, im sure i can do a decent job of it. But i might just mount the gauges as they come, they have their own mounts or i can buy a holder. I would prefer a holder, they look better, but if its that much harder then ill just mount them on the top dash with their stock mounts
They pop up on ebay a fair bit, and in the SAU for sale section.
This might be a noobish question, but will this work if using a piggy back system such as the eManage Blue? I would imagine that the data coming from the ECU would be data before being remapped by the eManage and therefore probably wouldn't show correct data on the ecu talk... or am I mistaken? Looks like something I might add to my future mod list if it will be compatible.
it reads what the ecu sees. so if the ecu is being tricked into believing lower AFM volts, then it will show the lower AFM volts (and if thats the only signal intercepted/modified, wont make much difference). outputs like injectory duty % will be unaffected.
I got Water temp, oil temp and oil pressure in the Defi BF series. Pretty sure they are legal there also.
See thats probably what im gonna end up doing, just mounting the gauges without a holder, same place you have them. Is that cable going into your aircon vent from the gauges? Or how did you get the wiring through the firewall?
i think you may find that injector duty may be different. the SAFC is just a afm signal bender, but others like the emanage can alter the injector rates without just bending the afm signal (which also results in a timing change). the emanage just intercepts the injector signal from the ecu to the injector then alters it a bit to get the required injector duty.
ahh yeah if it also modifies the injectors or timing (if thats possible) then those outputs will also be inaccurate. but with that much 'trickery' going on, i wonder if it wouldnt have been much better to get a daughterboard/remap/nistune type setup.
back on topic, ive actually thought of making a digital gauge that hooks up to the consult port and allows you to set it up to read one of the readings (be it water temp, speed, volts, etc). e.g. a 4 digit LED display with decimal point. mainly because people are used to mounting gauges and not so much mounting rectangular displays. if only i didnt have a real job i might have made it already :P ive been too slack on updates to the LCD display anyway, so thats first priority.
Goes through the air con (had to drill a small hole) then into the controller unit (near my left knee area). The only wires which go through the fire wall are the ones for the sensors, and they go through the bit just above the accelerator.
Dammit, all this gauge talk has got me looking into supplying them again. I did have everything ready to go with being a supplier for SAGA and Swoosh but the LEDs got me too busy. I've contacted them again so may go ahead with it. Get the car back to commercial jet form :banana:
Yeah no problem, funny though I just found some stock from a while back, the SAGA/Swoosh equivalent of the Defi Link series.
I should put them up for sale. Boost Gauge, Exhaust temp gauge, oil pressure gauge and oil temp gauge. They all daisy chain together and come with a remote control (instead of the control unit DEFI uses) and include all sensors :P
They've only ever been out of the box to see what they look like, then forgotten about in the garage.
Dammit, you guys have started me ricing it up again :)
How's this, fits perfectly where the "useless" lighter was, it's RFID so knows when the driver is in the car....has a nice Aluminium bezel so matches the interior well.
1 push = Acc
2 pushes = On
or
Foot on brake and 1 push - Ign!!!
looks good dan! Almost looks like its meant to be there. I use my cig lighter though for my GPS though that's an easy work around.
Yeah, you can get those cig lighter extender things with two of them on, can go in the ashtray (where the lighter should be anyway)
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
