Good Tow Cars?
That is why I paid $13k for an LPG powered Patrol, same thing running diesel would have been $23k+, and I feel comfortable with 2.5t in front of the Gtr. Sure there is no point spending a million on a tow/daily but having 2t of pride and joy behind a 1.8t tow car (plus tools etc) is begging for trouble, and if your tow car is overweight I am guessing your load is not covered by insurance either..
A Falcon would be the fallback tow vehicle for me, once some business is sorted then I'll know how much $ is available. Spent heaps on the track car, now it's time to get something decent as a dual purpose only one vehicle thing. Could get a gearbox chewing BMW X5 or Merc dodgy everything SUV if 'style' was the main goal :)
That last pic... Farken hell!
If anyone is looking for a falcoon tow car, hit me up, just moved house and it won't go down the side of the driveway I need it to while empty yet alone with a car trailer. (major advantage 4WD, ground clearance)
I use a 92 EB Falcon wagon to tow 2 tonne of race car/trailer plus tools/fuel etc in the back of the wagon to race meets for last 2 and 1/2 seasons. It's a 4L straight 6 which is a rare 5 speed manual (was an ex Ag department tow vehicle) and done well over 500K+ in its long life. I wouldn't say it does the job easily but it does the job and hasn't let me down yet. What was needed to get it over the line as a tow car was: 1. Properly rated tow package - Ford item is only rated to 1500kg 2. Air springs on rear - essential to keep car level (and stops the mud flaps doing any work!) 3. Electric brakes on both axles with override system - legal requirement if over 2 tonne which pretty much any Skyline will be on a trailer. My car weighs 1250kg but trailer is 700kg. Add a spare trailer tyre, some spares inside car and couple of jerry cans and well over the legal 2 tonne limit for single braked axle trailer) 4. Stay out of 5th gear - is always going to be the first one to snap! Is being retired once my new Jeep Grand Cherokee CRD arrives!! (This week hopefully after 4 month wait!)
Edited by Nissanmania
wheel there ya go
keep it under two tonnes or ya f**ked
15.2 All other trailers that do not exceed 4.5 tonnes ATM
These trailers must be fitted with an efficient brake system that complies with ADR 38/-. Except for over-run brakes, all brakes must be operable from the driver's seat of the towing vehicle.
For trailers up 2 tonnes GTM, an efficient braking system is considered to have brakes operating on the wheels of at least one axle. Over-run brakes may only be used on trailers that do not exceed 2 tonnes GTM.
Every trailer over 2 tonnes GTM must have brakes operating on all wheels. The brake system must cause immediate application of the trailer brakes in the event of the trailer becoming detached from the towing vehicle. Under these circumstances, the brakes must remain applied for at least 15 minutes.
You guys should just get lighter cars ;)
Trailer is 420kg's and the car is around 550kg's wet. I was previously towing it with my AU Falcon, which does it with ease. Have also towed it with a 2010 Jeep Cherokee, and obviously it's no sweat.
As I now require more space for spares I've just picked up a Q7 4.2 FSI with air suspension and a 3500kg towing capacity. The space in the back for parts is ridiculous, and should do the job very nicely indeed.
well after moving to perth and towing my R32 gtst behind my 2002 holden rodeo with 3.2 V6 manual petrol, i can catagoricaly state that it is not a great tow vehicle. it got 300k's to a tank, and with a strong headwind at one point about 250k's. it worked out to almost 20L/100kms.
Probably not to bad for towing to the local racetrack, but shithouse over long distance. technicaly it is overweight by a couple of hundred kilo, as the rodeo is only rated to 1800 kg's.
Its a great car in a lot of other ways, and im not going to get rid of it, but i wont be towing the 'line very far purely because it costs too much.
Ahh, you won't regret the new car. My 8 month old diesel Grand is for sale now (financial reasons)!! any takers?
Just another reason that GTR's suck. They're over 2k on a trailer. Nearly 3k if you carry enough engine oil to keep the shitbox full for a day's sprint......
:P They are cool!
A friend has a 'cruiser and averages about 25l/100km towing his Radical, though it is an enclosed trailer so the aero would be rubbish.
you could use an excel to tow the radical phunky.they are so light
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
