Noone tried a turbo diesel KJ Jeep? In theory it ticks all the boxes except the five speed auto does not have a sports mode sequential shift. My problem is that what happens if it cracks up on the Newell? Stranded big time?
I'd like to know how/why, considering that under the skin they're effectively the same vehicle.
Exactly, Although I have heard lots more about tailshaft, driveline etc, turbo and electrical problems with the ToeRag's, but that probably just because they are more common?
q7 minor service 350 ( every 15000)
major service ( every 30k) 600 ( every 30000)
i change the oil evey 7500km costs $150
in the next week ill let you know how much gearbox and diff oils are
still waiting for teh engine to explode and it does some hard yards towing my POS
fingers crossed
their so shit ill be upgrading to the v8 tt to hall arse faster in 12 months
I never said they're shit you cranky sheet carnt. :P
I've towed using Q7 (R34 GTR) and Toureg (R32 and R34 GTR's), both V6 TDi, and I reckon they're a bloody fantastic tow machine!
However, the fact remains they scare the beejesus out of me post-warranty.
Me too...and I bought one out of warranty. :O Service in a few weeks, sphincter is tightening already.
I dare say that's something to do with it Timmay.
I also recall Capt Fathom's Q7 engine (3.0l TDi) exploding spectacularly while towing his car to Lonnie from Devonport..... still under warranty thankfully.
Was Bourkey driving it though??? Lol :ph34r:
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
