Stock air intake on the Challenger, which you think would be the same on a Triton, is at the middle behind the gap under the front of the bonnet. Tried my Challenger on cruise control at 100kph, absolutely rock steady. Sequential shift is handy, auto is smooth, engine is willing but it drones at 1700rpm in a high gear which I suspect is because that is just below the best torque range. Overall, so far so good :)
Fantastic news, have you towed with it yet.?
You might have found the best compromise tow vehicle (apart from the falcon - lol )
Won't be doing any towing for a while so can't comment on that. But the auto is detuned to 350nm whereas the manual is not, around 400nm I think so the auto is not going to be too spectacular. See that MRT offer a retune service to get them cracking, would bugger the warranty though for sure.
the auto is detuned to 350nm whereas the manual is not, around 400nm I think so the auto is not going to be too spectacular. See that MRT offer a retune service to get them cracking.
Got any plans to plumb in a decent trans cooler? Most modern multi speed autos seem programmed to shuffle down gears pretty quickly as soon as you hit a rise or hill. Generally keeps average road speed up but can increase temp loadings on the transmission while the torque converter locks/unlocks.
Interested to hear how the Challenger gets on for chassis stability and fuel consumption once you have a few towing miles under the belt.
It's funny there is not much mention of towing in the handbook, no mention of not using fifth gear (auto) for towing. There is some mention of using a lower gear if the coolant temp rises when going up a hill and that's about it., No tow pack option except for a towbar, no mention of an extra cooling device. Sounds like MrBitchy think that towing is no big deal. My idea would be to keep engine revs in the peak torque band whatever the terrain.
Plenty of people using Challengers for towing, from what I've read the vehicle is basically very suitable for the job, keeping in mind that there are bigger more powerful tow cars around. It's a bloody truck, it has to be able to tow :)
On towbars, the bloody ripoff prices around. Ended up with a Hayman Reece 3 tonne rated for ~$465, bitch of a thing to fit but a nice peice of work.
Ohh. Check engine light on the q7 today
Turns out some intake manifold flaps are only opening to 92%( variable intake track), which throws a check engine light
150 to fix my flaps
Lol
Flaps
Lucky it isn't the flange that died... You wouldn't be able to keep a straight face while talking to the dealer :P
And isn't it under warranty?
Looking at either a ba or au wagon (or maybe ute) for like ~5k... what would people reccomend? A bit better condition au or an average BA? Know they're similar but hoping someone knows a bit more about fords than me...
Just came back from a decent towing session down south in the work AU Sedan (4L, 6-Banger, 225k kms) towed my FC RX7 so nothing crazy. Ate some fuel with the weight in the back but didn't mind the trip home with only the trailer and no car on it. In saying that I wouldn't reccomend it if you wanted to tow every other weekend.
if given the limited option though I'd go the BA wagon, leaf springs will take the tow ball weight nicely and the slightly newer engine would be preferred. You also get the advantage of locking your shit in the boot and rear seats ;)
Edited by Hank Scorpio
Towed my 33 with a 2001 AU gas Falcon, also on board were tools, trolley jack, extra fuel and spare wheels, 400kms combined. Used one tank of gas.
Will probably replace the 180,000km old rear shocks and springs next time around for a bit of extra height.
Apart from that it did it pretty well.
I'm looking into a holden adventura wagon as my next towcar.
Anyone had one or any idea how they are?
my old boy bought an adventura when they first came out, the v8 model thinking itd be a good idea to tow the wakeboard boat, dirt bike trailer and camping trailer, it didnt mind the lighter trailers but it struggled with the boat, and as for the car itself, super UNcomfortable and really not all that crash hot to drive ..
my brother has a BA series 2 xr6 falcon ute, which we use to tow the new 3 bike trailer and it struggles a little up the big hills like Mt Sugarloaf but only the striaghts and small hills it tows it just fine ..
if i had a choice, i would buy a 100 series Landcruiser, we go to Fraser Island yearly and tow a fully packed camping trailer and it has no troubles what so ever, and the seats and ride quality are great, especially in the v8 auto's !!!
What's the would be the amount of difference to the power to the mrt tune?
Was curious as to the power increase expected with the mrt tune?
There is some info on the MRT site but no specific power outputs mentioned, unless that has changed.
Reading the driver's manual I see that there is a auto trans overheat light which is handy. After crawling underneath it to fit a tow bar etc it is definately a truck, no doubt about that :)
Edited by 260DET
Apparently the auto trans overheating light is part of a partial shutdown system, once it is triggered it blocks the use of higher gears so I'm told. But I have not heard of anyone towing triggering the light yet.
Plenty of chips around for Triton/Challenger eg Chip It http://www.ebay.com....=item43a55b3d6a
Going off the Triton dyno sheet there torque is calculated at 396nm @ 2750rpm, 216 @ 3750, at the rear wheels. Stock manual puts out about 400nm at the flywheel so say a 30% improvement over that. 520nm by my dodgy calcs, wonder if the auto box which is limited to 350nm would stand up to chip power? Might need an extra cooler for a start, 520nm is not bad for a 2.5 liter engine eh :).
Edited by 260DET
    • Which model Maxima? This is good knowledge to have.
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
