I feel weird saying I have a bit of badge snobbery by leaning toward the Hyundai :P
Toyota FJ is basically a Prado underneath I understand, so should serve you well.
They're but in the USA? Does that explain why no oil burner donk?
hello friends,
am looking at buying a diesel tow car/4wd with a budget of 10 -> 15k. it would be towing my S14 on a car trailer.
i was leaning towards a 80's series landcruisers post 96 were the tow rating was changed - what are opinions on these?
can anyone please suggest some other options that would suit my price range?
cheers
hello friends,
cheers
Are you needing anything else from the vehicle other than towing ability?
Seating capacity, daily driver, economy requirements........ ?
not so much, mainly just towing and off road ability for some fun
half decent fuel economy would be nice but i have a daily also so not essential.
cheers
Well as soon as you say "off road ability" which I reas as "serious off-road ability" I instantly think live front axles.
So, 'Cruisers and Patrols are on the menu, wagons or utes depending on what suits. Avoid British shit but we all know that.
Don't get carried away with lifts etc, coz the higher you go and the bigger the tyres, the worse they tow.
Diesel Cruiser or Patrol, aftermarket turbo kit if it doesn't already have boost. Budget i9s the hard part.
Personally, I'd be having a crack at busting this bloke's chops, or trying to find a GU Patrol ute with 4.2 turbo.
http://www.carsales.com.au/private/details/toyota-landcruiser-1994-14020428?base=1216&vertical=Car&cr=10&eapi=2&__N=1216%201246%201252%201247%201282%204294962861%204294962570%204294680273&num=15&silo=Stock&Range=Price%3a10000%2c20000%7e0.5&sort=default
yeah 'serious off road'
wow at that link. 20k seems pretty crazy. newer versions are much cheaper here in perth >.<
not sure it would be up for the towing capacity either
pretty much what i thought - will target the cruisers and pooohtrols
cheers mang
cheers mang
New ones attract less money because they have the shitbox ZD30 in them and will blow up. If you read back I rave about my 4.5l dual fuel Pootrol quite a bit, but think it is justified, I get 18/100 driving daily, heaps cheaper to buy and run day to day than a diesel, and debatable how much more it costs towing.. The 4.8l is a heaps better motor again
8.4L/100 is good for a truck, how does it drive.
Now have a trailer for the Challenger, PI over easter is the plan. It's going well, only thing is the suspension needs tuning for Aussie roads. Thinking about getting a set of Bilsteins to improve it.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
