Good Tow Cars?
Couldn't agree more. No disrespect to people who had 'old Jeeps' but in general they were $hit. Fiat ownership has brought along European design influences and more importantly European production standards. The fit and finish and general build quality of the Jeeps is spot on. I've never seen a brand go from junk to top quality in such a short period of time. If I wasn't building a house, a shed and a car I'd have one for sure! Driving one as a demo whenever I like is a suitable alternative though!
One point about the Challenger. It may be rated to tow three tonnes but two is more realistic in my experience, particularly where people put those bloody awful tyre racks up high on the trailer. Race car? Heard about aero drag? It's true, take notice.
Mines an auto which has less engine torque than the manual. Some tow more than 2T with the auto no problem but I'm conservative with any recommendations, particularly as some want to tow 4WD bush style.
Towing back from Wollongong to home via the city was a flamin mongrel of a tow!
heart break hill up from wollongong was the first time my santa fe struggled!
dont that a few times awesome test with some bends
absoutly shithouse in the patrol and prado
epic in the audi ( even though they have a symbol on the front and back that looks like two mens balls touching, they love big hills with a load)
  • 1 month later...
Picking up new amarok next week, will see how the little 2 litre goes. Before I get flamed for not buying a patrol or cruiser, the wife will end up driving it more than me so It was a compromise.
Daily comfort vs towing practicality. I'm sure it will capable of pulling the axe plus tools.
I wouldn't worry about getting any stick about your purchase unless you bought a falcon.
the patrol is now coming up 400 k and still tows every day. maintainence to date. brake pads and tyres. and, shock horror, i split the top tank on the radiator a couple of months back. a 400 dollar fix.
I reckon I should have recieved warranty for that.
But, Pat Callinan will be proud of you!
Anyone used a 1998 mitsubishi delica 2.8l turbo diesel intercooled for towing?
They are a basically L400 on steroids with 4wd gear using pajero floor/chassis i heard?
Dad has one and tows a ~1000kg caravan with ease he says.
Trailer will have electric brakes.
I would like to try it and see how it goes, otherwise i will have to get something else... but would like to see if anyone had any experiance.
cheers
Holden colorado rc 09 model lx duel cab, 3.0 turbo diesel
It tows brilliantly, barely cog back to 3rd on the way down to wakie !
Fuel consumption normally 655km/62ltr, towing around 575km
  • 1 month later...
cheers
Yep, used one heaps. Tow good, needed a good custom tow bar made though. We towed heaps interstate, was a great distance hauler for two blokes. The guy taking a rest could recline in back with a DVD. We did multiple qld to Tas trips, towing over two tonne each time. Electric braked trailer.
Should tow fine. Probably be thirsty, but should do everything else well. The Territorys have had a good name since they came out, so you should have a good run with it. Just check whether it has / needs a trans cooler, as many modern 4WD's don't, and they suffer when towing / beach driving etc. (I presume it's auto 6 speed)
As far as I'm aware it's not too bad around town but will be thirsty when towing. I don't think it needs a trans cooler being a 6spd (ZF) box. If it were a BTR I would put one on straight away.
Yeh that's what I meant - thirsty when towing. Petrol SUV's tend to be that way. Still, for the small amount of time you're likely to spend towing, that shouldn't be a major issue. All good if no trans cooler is needed.
  • Like 1
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
