It saves weight if you don't carry beer with you, buy it at the destination. My point is a modern medium/large suv makes a great tow bitch, way better dynamics, fuel economy and comfort compared with most ladder frame 4x4's. Particularly something with a V6 turbo diesel, struggling for power is a pain on a long trip..
Lol, what's this new trailer called, B Double?
Solar powered fridge is good, the lift pump battery on my trailer is charged by solar power which saves a lot of stuffing around on a trip.
Edited by 260DET
  • 5 months later...
I'm a towing newb.
Our 'big car' is a Mazda CX7. Be kind. Would you tow a car behind it?
That said, I think its only rated to 1700kg's braked, which doesn't leave much for a car considering the weight of the trailer. :(
 Not a great choice in my opinion mate. Even towing the R33 with my pretty heavy Ranger Ute I can feel it moving me around a bit on the road. A light little SUV like a CX7 would be dangerous in my opinion. A good gust of wind and you’ll be on the other side of the road!
The average car weighs around 1400-1500kgs so you’re right, it doesn’t leave much room for the weight of the trailer if the total is 1700kgs!
I'd do it one-off for slow and shorter trip, but not regularly. For a start most car trailers are 500-800kg so that means the car you are towing is limited to 900kg. And even then when you tow right up to the load limit you often learn that while the chassis can take the load, the engine won;t deliver the performance to tow it safely (hello creeping up hills on the freeway)
On 6/15/2018 at 10:40 AM, fatz said:
True
if your under 5’8 go defender
if you any taller you won’t fit
Or if you enjoy punching the underside of the dash with your knuckles ever time you put the handbrake down.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
