Auto Tdi's just work. I've gone from a 6 speed manual pathfinder to a 5 speed auto Pathfinder and the auto is much smoother and better for towing, specially reversing into the driveway, manoeuvring around the paddock at an event etc, I'm not a fan of autos either, but for towing, auto tdi is the only way to go. Just be careful as some might need a trans cooler fitted for heavy duty work.
Huyndai have lifted their game, and the drivetrain in the santa fe (same as the Kia I believe) was actually euro designed and built. I don't care what anyone says - the euros have the expertise in turbo diesels, and Japan is only now cstching up with them.
The mid range suv's make great family cars, by the way. Our pathfinder gets used most of the time, and it's easy to park, great visibility, comfortable and cheap to run. The rex only gets taken out when I want to get from point a to b quickly, or want to have a bit of fun.
I don;t know what kind of TDI SUV you're going to get for $20k though. We sold our 5 year old pathfinder for high 20's, and it spent a good deal of time belting around mine sites and towing rally cars through the bush. Still, scrubbed up clean enough so we did ok on the resale.
Seeing I have to get a tow car sometime have done more research in the $20,000 diesel SUV/4WD category. Quite a few various model Nissans, some with quite reasonable k's for that money on Carsales. Thanks for your tips Ben, no Merc for me then :)
Edited by 260DET
Ok...I remember Jeeps being mentioned before (the V8 ones)
any one have thoughts on teh mid 90's Cherokee with the 4L six?
seem to have a 2.2ton braked tow capacity which is perfect, what are they like to live with, I hear they are pretty bullet proof too
Definitely need to fit a trans cooler if you want to tow with the 4L Jeep. We towed from Maitland to Coffs, and the transmission nearly shat itself going up the range north of Tamworth. It overheated and started doing all sorts of weird stuff
Apart from that, it seemed ok for towing, but it was nearly new at the time. don't know how they would have fared with 15 years and a couple hundred thou on the clock.
Wont be towing any great distance (wakie is only an hour away and mostly flat)
Transcooler is a must for any auto imo anyway
What was it like to live with? I know they are a little truck like but I can live with that if they are resonably comfortable
It will be a daily most of the time and the missus has to drive it too
It wasn't mine, so I didn't have to live with it. At the time (about 96 or 97) it seemed pretty plush for a 4WD, and I got the impression that it was a luxo SUV without any real SUV capabilities, but I've always been that way about Cherokees, so probably a biased viewpoint. From memory, it seemed to do everything else well enough, the overheating trans was the only thing that stuck in my mind. It belonged to a company director, so he only had it for a couple of years before moving on to something else.
Anything over 2000kg with power to match will make a decent tow car, trick for some of us is to find a DD that will do the tow car thing reasonably well. Not everyone wants a stump pulling 4be truck in the garage :P
Edited by 260DET
Three months in and I am happy to wave the q7 flag again
Awesome tow car(so much better than the potoroos and prado I have had)
Tow rags can be cheaP and are the same cars but smaller
Q7 is AWD, very unlikely to get you out of slippery situations towing.
Touareg pre 2011 is 4WD with low range, gets out of slippery situations towing whatever.
Talking from experience after owning both, unless you particularly wanted Q7, VW does the job better, quality is on par with Audi
Yea low range is a bonus for reversing with a trailer
Tow rage is cheaper so a good buy
Boot space is shit for a family truckster though
Fatz, I'm not doing this to get into an argument, just so the facts are there for anyone considering a good tow car.
Not only bonus for reversing?, I was more thinking of driving forwards through say, a wet grassed parking area. Have been stuck with Q7, never with Touareg, even in mud.
Depends what year, but yes, generally VW 3.0TDI is cheaper.
Never found VW lacking in boot space, compared to Q7, remember Q7 is longer but roofline tapers down, VW is upright, more rectangular.
Just sayin'.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
