I feel weird saying I have a bit of badge snobbery by leaning toward the Hyundai :P
Toyota FJ is basically a Prado underneath I understand, so should serve you well.
They're but in the USA? Does that explain why no oil burner donk?
hello friends,
am looking at buying a diesel tow car/4wd with a budget of 10 -> 15k. it would be towing my S14 on a car trailer.
i was leaning towards a 80's series landcruisers post 96 were the tow rating was changed - what are opinions on these?
can anyone please suggest some other options that would suit my price range?
cheers
hello friends,
cheers
Are you needing anything else from the vehicle other than towing ability?
Seating capacity, daily driver, economy requirements........ ?
not so much, mainly just towing and off road ability for some fun
half decent fuel economy would be nice but i have a daily also so not essential.
cheers
Well as soon as you say "off road ability" which I reas as "serious off-road ability" I instantly think live front axles.
So, 'Cruisers and Patrols are on the menu, wagons or utes depending on what suits. Avoid British shit but we all know that.
Don't get carried away with lifts etc, coz the higher you go and the bigger the tyres, the worse they tow.
Diesel Cruiser or Patrol, aftermarket turbo kit if it doesn't already have boost. Budget i9s the hard part.
Personally, I'd be having a crack at busting this bloke's chops, or trying to find a GU Patrol ute with 4.2 turbo.
http://www.carsales.com.au/private/details/toyota-landcruiser-1994-14020428?base=1216&vertical=Car&cr=10&eapi=2&__N=1216%201246%201252%201247%201282%204294962861%204294962570%204294680273&num=15&silo=Stock&Range=Price%3a10000%2c20000%7e0.5&sort=default
yeah 'serious off road'
wow at that link. 20k seems pretty crazy. newer versions are much cheaper here in perth >.<
not sure it would be up for the towing capacity either
pretty much what i thought - will target the cruisers and pooohtrols
cheers mang
cheers mang
New ones attract less money because they have the shitbox ZD30 in them and will blow up. If you read back I rave about my 4.5l dual fuel Pootrol quite a bit, but think it is justified, I get 18/100 driving daily, heaps cheaper to buy and run day to day than a diesel, and debatable how much more it costs towing.. The 4.8l is a heaps better motor again
8.4L/100 is good for a truck, how does it drive.
Now have a trailer for the Challenger, PI over easter is the plan. It's going well, only thing is the suspension needs tuning for Aussie roads. Thinking about getting a set of Bilsteins to improve it.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
