I've got the older (2008) ML Mitsubishi Triton - 3.2L auto with factory chip 132kw and 420nm 2300kg tow rating. Happily pulls the skyline on a tandem trailer with full steel deck (i.e. heavy ass trailer) at any speed required. Only gripe is the 4 speed auto isn't quite geared right for hilly NZ roads, sometimes seems like it wants another gear between 3rd and 4th up hills.
Can be had pretty cheap these days with reasonable kms on the clock.
As promised here is my towing report using the Challenger to PI and back. Tows fine, no problems there. Just keep in mind that it has a 2.5 liter TD with a torque reduced auto transmission. But stuck her on cruise control and it delivered 11.6 l/100 average over 1720k of varied road and traffic conditions, from 110kph down.
A Jeep forum may be the go for the Cherokee, good luck.
Falcons have been mentioned here a lot, had a chat at PI with two mature age WA blokes who had towed their Z cars over with latish model Falcon utes. One a six, the other a V8. Both were happy and will do it again, that's a pretty big plus for ye olde Falcon.
A real tow car test is 110kph* down hill on a winding road when you have to brake to avoid the revenue raisers, if the tow car ignores the tail trying to wag the dog then it's good.
* legal speed limit, which always makes sense and is safest. Govco dickheads.
I went from hydraulic to electric brakes on both axles and i have not had the " wagging tail " problem since :)
Airbags are going in as the 22yr old springs don't like the wieght ., I have done 100,000kms of hassle free towing with the old 4.2 turbo diesel
so the santa fe had its first towing trip.
managed 9.2L per 100 down to Wakefield from Gosford. 280kms
some times I had to remind myself i was towing however the noise did remind me.
being a wagon the noise from the hitch was quite loud going over bumps and stuff. in the commodore no where near as loud.
coming back managed 9.7L per 100 as the stupid M2 had road works and of all the traffic lights from M2 to F3 I got 95% of them as red lights haha
Is anyone using a Toyota prado for towing with?
I'm looking at upgrading my old pajero to an 07-08 prado with the d-4d common rail turbo diesel with the 5 speed auto to tow my r33 gtst with.
Plenty of folks have and I'm sure they'd be just fine.
Sounds promising!
Is the the hitch "tongue square" or the ball/trailer that's noisy? A bit of fiddling can get rid of a lot of that.
Bolt/nut for the hitch square to take the slop out, and tighten the trailer hitch adjustment over the ball.
Very good economy!
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
