well i use a bf xr6 turbo 6 spd auto ute to tow now, tows much better than my old fg xr6 sedan used to, much more stable plus much more room for tools, lunch, fuels, etc would go a ute anyday!
Get a wagon, even better!
Be warned, a manual is not certified to tow that much weight... no doubt it is just a warranty thing for people that abuse their clutch/gearbox, and has nothing to do with what it can actually handle as far as stability and stopping goes.
But if the worst happens, you don't want your insurance company going 'oh, sorry, your car is clearly only allowed to tow 1200 kg (or what ever it is), no payout for you'
Insurance companies can be assholes, I know a guy that ended up with a huge bill when his old shit box got hit by another car - and it was deemed his fault cause his backyard paint job was deemed to be the issue - not as easy to see as the original glossy paint apparently.
You don't want to give them any outs.
Edited by samstain
Caravan Trade and Industries Association of Queensland in conjunction with RACQ publish a comprehensive Vehicle Towing Mass Guide based on manufacturers' specifications:
Holden Commodore VU VY V8 s / ss Utility man / auto 12/2000-08/2004 500kg unbraked 1600kg braked #1 Load level hitch req'd over 750kgs. #9 Owner's handbook MUST be referred to for additional vehicle fittings when towing.
The only Commodores rated to tow 2100kg in that model are the auto sedan, wagon (ex VY factory LPG Wagon) and one tonner, and even then it has this condition:
#8 Max 80km/h over 1600kg.
Commodores and Falcons are simply not a great choice for a tow car.
  • 1 month later...
http://www.skylinesaustralia.com/forums/topic/400054-fs-2001-nissan-cima-vip-45-v8-23500/?hl=cima#entry6890924
Nissan Cima?
Any thoughts ?
V8 luxo barge much better daily than a 4wd obviously less economical than a diesel for long trips but occasional towing it might be a goer?
Edited by noone
I'm not sure if towing stuff is legal in Japan? So domestic models may not have manufacturer tow ratings. If they are rated at all, it's fair to say they unlikely to be any better than the local Falcon/Commodores which are rated to 80km/h max over 1600kg with load levelling kits and stuff.
Edited by hrd-hr30
So not a D22, mine sucked for towing, even when almost brand new. I had my WRX (early shape) on a light weight trailer for and all up load of about 1900kg, and it couldn't maintain 80kp/h into a slight headwind, and going up hills was even worse, I took it to Nissan, and they gave it a clean bill of health, it got run on a dyno and the figures that it made where line ball with the stated outputs for the engine as well.
Y61 Patrol 4.5 litre petrol big girl,,,she tows like a gem,,,.
Not like the crappy falcon wagon swaying/wobbling box of shit we killed. It did last 4 years but was a pathetic tow vehicle under load. I couldn't ever sleep while the boss women was at the wheel,,,not that she can't drive,,,I just didn't trust the car.
Sure the Patrol chews the juice but is as stable as and accelerates up most hills,,,we tow about 2000k usually (car and trailer).
Admittedly she not our daily driver,,,so fuel is not an issue and we will buy the 4.8 litre one when this girl has run her course.
Nissan all the way.
Cheers
Neil.
I have a 2007 chevy 2500hd 4x4 with a Duramax with all kinds of upgrades for sale here in the US if interested? It'll tow anything you'll give it. Shipping might be costly though.... Just throwing it out there.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
