So my 2011 d40 navara tows great, good economy and all, but new house has a steep thin driveway i wanted the trailer loaded at the top, heat warped the dual mass flywheel doing it, lesson is dont reverse 2t up a hill slowly, you have to ride the clutch a little to control the speed and it heats up the flywheel... So its new clutch and single mass flywheel time already...
Tip from clutch guy i spoke too, reverse in 4lo even on concrete and all will be find and easier to control speed rather than having to ride clutch a tad...
$2k for new clutch flywheel fitted, bugger
That is a great old 4WD trick - to put it in Low Range whenever you are going to back a trailer up - no clutch slipping is required and you can easily move a loaded trailer into a trickey spot or up a steep driveway.
Which is why auto TDI tow trucks rule. Had a manual pathfinder, swapped for auto and would never look back. Race and rally cars are for fun so no need to stuff around with gears in the tow truck as well (despite my posts in other threads saying autos are ghey. Ignore those comments for the purpose of this argument)
Only possible if it's an old fashioned part time 4WD with manual locking hubs. It's the main thing I missed about my old Patrol.
If you have a part time 4WD (with transfer case) and auto hubs, this will put it in 4wd and you risk binding the transfer case if you're turning while reversing the trailer. D40 is in that category, so selecting 4L and reversing is not an option if you need manoeuvre the trailer at all. Unless there's a pov spec version with manual hubs?
And constant 4WD things (with center diffs) normally only go to low range with the centre diff locked. Again, this risks damaging the driveline. Low range reversing not really an option
Edited by hrd-hr30
The cruiser locks the centre diff lock when in low range... Makes it a pain in the ass! I found there is a way to disable it but i cbf...
I guess this is as good a place as any to ask...
We're contemplating an 80/100 series Landcruiser, which we'll probably keep and run into the ground. It'll do a lot of medium-distance towing (600km round trips) and eventually be a farm hauler too, but will probably be the mummy wagon from time to time. Since I'll be doing all the maintenance (and hopefully mods) myself it needs to be relatively easy and simple to work on. Is it much of a drama to work on the 4.2TD models? Also, is there any downside to the 1FZFE petrol engine other than going through fuel like there's a hole in the tank?
Wihle I'd love to go for a TB48-powered GU Patrol they're like hen's teeth over here and highly priced when they turn up.
Nothing wrong with the Toyota motors other than the petrol sixes valve stem seals.
The 100 series 4.2 turbo diesel is an absolute cracker!
This is what i want to upgrade too!
Heard first hand from a bloke who has a Toyota V8 diesel from new, fuel system failed at around 130k, cost him something like 8 to get it fixed. Toyotas are not what they used to be, particularly the diesels.
When I was working for Nissan last year I borrowed one of the STX550 Navara's to punt a car trailer around with the old GTR on it. With the 7 speed auto and the power and torque from the V6 3 litre turbo diesel it drove the same as when it was unloaded.
Now I just have to buy one dammit!
I was wondering why they only have a towing capacity of 3T compared to other cars with less NM that have 3.5T... We looked at an ST550 and it didnt look all that exciting! Would be nice to tow a nissan with a nissan though :P
  • Like 1
Towing capacity has about 13.75%(*) to do with engine power / torque and 86.25%(*) to do with vehicle mass / stability / chassis rigidity. A 430kW / Zillion NM HSV GTS has a lower towing capacity than the Navara
*Percentages for illustration only. Actual results may vary.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
