Yeah I would have to say that heading up the big hill coming out of the gong is a struggle for any car.
Up mooney mooney I can sit on 100 if I really want to but I usually do about 80 to 90 up the hill.
got to love the falcon
I'm talking all the hills on the F6 from Wollongong to Sydney, not just climbing Mt Ousley.
on the BA manual, beware of redbook, not all of its figures are accurate. From memory when i was researching all manual ba-fg xr6t had a 1600kg towing limit. Clutch and box don't like the strain.
also, i much prefer the having a lot heavier tow vehicle, just imagine what its like pulling up a 2.3t trailer with a 1.5t car when the trailer brakes fail.
or even worse even if you're halfway around a bend and you need to slam the brakes, chances are bad enough of jack knifing with a 4WD, youre nearly guaranteed it in something like a falcon or commodore.
  • 11 months later...
4wd all the way
if your trailers and car are close to your tow limit just add fuel and tools and your well over
not worth the risk
Sorry to bring back an old thread but i couldnt help but think how funny fatz is talking about safety. If i remember fatz car trailer was the thing of ledgend for being so damn dangerous even the tyre rack fell off one time and i had to weld it back up.
Mmmm death trailer was the reason I got my first 4wd
As a upthedatefor this thread
Q7 approaching 200k on the clock
Still tows like a mofo..loves 3 tonne out the back
Do recommend and for the f**kers above I think you can pick one up for 20k now
I must say I have been eying off a few v12 q7s as a upgrade recently
Why not the V10 Toureg, and pocket the massive difference in change? I've driven one of those towing a big arse trailer. Was like nothing was attached to it.
Excuse ignorance, but much difference between them?
v12 has 500hp
Have owned QE7 and TOUAREG V10, both very capable, V10 noise under load like rolling thunder, main difference besides size is that if you venture off road into slippery stuff , the VW will be pulling out its sister. Haven't driven V12 so cannot comment.
For under 20K I love my 4.2Turbo Diesel Cruiser. 2000 model.
Not quite as quick as Fatz pram, but if you do go off road it goes pretty darn well :P
So well that I sold the car trailer I bought to tow it so I can 4WD more instead :P
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
