There are too many variations with ECU’s Teren.
I will require a VIN number (original Japanese) to be able to trace the correct part. A part number off the ECU itself will be sufficient.
Many Thanks,
Andrew
....vin or part number please guys....
  • Replies 111
Posted Images
There are too many variations with ECU's Teren.
Many Thanks,
Andrew
Just incase there are any problems with the vin # the markings on the ECU (courtesty of Iain) are:
Nissan JA
A56-R12 L18 1Y03
UNISIA JECS CORPORATION
JAPAN
It's also a negative from NissWreck, they are unable to assist.
I was trying to get them to import a wrecked M35 in there next container, but alas they can't help :)
I asked if they could just bring the ECU in but same result!
ok so i will cal my brother and get him to track down whoever bought that black wreck off pickles the other week who tried to sell on ebay..
I was wondering where that cowboy got to, the only real option he has with the car is to sell it whole to a wreckers or to part it up himself. It can't be re-registered so he is really up the creek.
Let us know how you get along, would be interesting to find out what become of the car once it was taken off ebay.
A few people said they had emailed him but I've not seen any feedback to say that they had got a reply.
Called him today, hes found a few front cuts in Brisbane, but they wont separate the ecu from the fronts.
they said they will try grab just an ecu for their next container.
So i asked him to see if he can track down the black one for me as that seems like the easiest option.
F*CK, you'd think if they were front cuts they wouldn't mind seperating the ECU, I gather they want someone to buy the whole lot just for one part? f*ckity f*ck
Yeah, I'm still interested to find out what become of the black one that was removed from ebay.
http://www.importmonster.com.au/view?url=h...g&title=833 H16 M35 250RS V CPU
says m35 2250 rs v but numbers are no where the same as Ians....
I don't think that is the right one. Needs to be a 250T RS
Any is correct, that isn't the ECU we are after :)
I'm starting to think this is going to be a long and difficult process lol
Can anyone let me know which wreckers have the front cut (or whole M35) as I need a small plastic scoop vent sort of bit. Thanks
If you mean the cold air intake scoop that sits above the radiator and directs cold air into the airbox, any V35 item will fit (same part).
Edited by iamhe77
nope it's asmaller one. Sits down below the grill on the left and is about 20 cm's long and scoops air into the intercooler.
Aahhh yes.
Mine had a 40mm split from the left corner towards the intercooler.
One minute and some "Tarzan Grip" later, it is a good as new... can't even see the split :banana:
I'm going to Brisbane in a couple of weeks.
Could you please find out which wreckers have the front cuts and get their names and possibly addresses?
I would like to see what other parts they might have - boost guage, wood trim, driving lights etc
MM
Aahhh yes.
One minute and some "Tarzan Grip" later, it is a good as new... can't even see the split :blink:
i bought some glue today and went to attach it and found out that some of it must have falen off on the road where the "ahem" incident happened :laugh:. So there wasnt enough left to attach it.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
