Hi All,
I just contacted Buddyclub Australia regarding to a set of coil over suspension for the NM35.
They do not sell them at the moment as they need to R&D for the right spec as in Bottom Bracket, Top mount and spring rate for our car.
But he reconk they will look into it and start a limited run for our car and I think its a good news.
They told me they need a minium 5 set of order for them to worth while to make this happen.
I have put my name down but I need 4 more car to come on board.
They have the D1 spec rrp at $ 2309 at the moment, they told me if we can get the 5 set happen,
We can have it for a very very special price, and Im not talking only 10-20% off....
So i reconk if we can get this happen it will be good for all NM35 owner.
regards,
David
https://www.sau.com.au/forums/topic/272163-m35-buddyclub-coilover-suspension/
Hi All,
regards,
David
Show me some more details and i would be keen as and happy to pay.........However i dont really want to be dicked around as research donkeys......keep me posted though.
Cheers
Yea, should be any problems,
The do have the V35/G35 already.
They have the USDM M35 4wd seden in the list and i belive it will be very close to our NM35,
But anyway Atleast I know someone is keen, I will give them a call tomo and see !
thankz all
dunno much about this suspension, is it good? Good company? I'm after doing the brakes and suspension as my first two big things so I'll certainly register my interest and do alittle more reading.
Brakes are easy. Just get brembos off v35 or 350z.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
