Hi all,
The name is Phil from Belfast In Northen Ireland, i have an R33 GTR V-Spec
Not a whole lot done to it ATM but planning a decent duild and some proper HP in the very near future..
Some pics for the Binliner
Mods so far...
Vi-Pec Ecu (Antilag + Launch Control)
HKS Down pipes
HKS Decat
HKS Racing Suction Kit
HKS EVC VI Boost Controller
HKS Cam Belt
HKS Oil Cap
HKS Radiator Cap
Rota Grid Drift 18 x 10 ET 12
Blitz Nur Spec R Exhaust
Momo tuner Steering Wheel
Tein Coilovers
Carbon Fibre Rear Wing
Carbon Fibre End Plates
Painted rocker cover and Inlet Manifold
Polished turbo pipes
Jun Carbon front Splitter
Carbon Exhaust Surround
XYZ front Brake kit 355mm 2 Piece Disks , 6 pot forged calipers
Cheers
Phil
https://www.sau.com.au/forums/topic/272201-hello-everyone/
Really Nice!
Should be proud o' that!
HKS piping is cool - but I'd just change the pods (or sponges) since searches will tell you that free flow is not good & filtering efficiency is not good (via HKS sponges)
Thanks Man, i always thought thay the HKS elements flowed really well but did not filter that well..Its the general consensus across here that you need to change them every other service...
Edited by Phil_Ai
https://www.sau.com.au/forums/topic/272201-hello-everyone/#findComment-4632998
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
