have been advised to change to ngk v power racing plug R5671a-7
On what pretence? It's a spark plug. The air/fuel mixture doesn't look at the spark plug and think "he's running R5671a spark plugs - I think I'll generate 20kW extra". It's a spark plug - it ignites the air/fuel mixture after it receives a huge jolt of electricity. It's the same size jolt of electricity, irrespective of the type or manufacturer of the spark plug.
It really doesn't matter what number is stamped on the ceramic, as long as the plug is designed to fit the application.
You will be wasting your money, IMHO.
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4624080
If its the plug I'm thinking they are as cheap as the regular coppers.
I personally didn't notice any difference, if anything it felt a little less punchy but that was most likely in my head. The idea behind the plug I believe is to prevent spark blow out at high combustion pressures.
Grab a set of coppers with a heat range to suit your power and you'll be fine.
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4625082
is anyone out there using these in there rb
I run them in mine but the -8's and indexed.
I will be doing a dyno test back to back with mine once final tune is done to show the difference so will post up after its done :)
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4625181
It sounds like a cop out on behalf of the tuner. A safe rich tune is only rich at high loads, and will still be leaner than a factory setup. there is no reason to be running 12:1 afr at cruise, all it does is wreck fuel economy, catalytic converters, emmissions, cylinder bores and spark plugs
https://www.sau.com.au/forums/topic/272216-spark-plug/#findComment-4626309
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
