Congratulations to all that got the votes and the positions....like James said that the people in the positions mentioned are the right people to get this mofo up and running....everyone has my support behind them.....Damo well done on getting the Web Editiors role mate if you need any help in that side of things then just let me know and i will try to help you out.....
Ruby are the meetings going to be open to club members as well or just the board members????
Well done guys. It is great to see that SA has got a club of the ground. Good luck to the new committee and I hope all things go according to your charter and 12 month plan to where the club needs to be to sustain numbers and events for future committes.
*Thumbs up*
as said before, congrats guys...definately would love a cams license to go along with my cams officials license...plus i'd love to have a go at a track day eventually
Rest assured, this is one of the first items on our to-do list. We will lodge the forms and fee asap, but the rest is up to CAMS to process the paperwork. When it is all ready, I will submit and also email a PDF copy and ask for a timeframe on the processing of our licence.
congrats to all. Good to see its getting off the ground, people might take it all abit more seriously now if things start happening(myself included)
ne question, what happened to kelly? Thought as she was apparetly starting the club her name would be in there somewhere, or at least have been a paid member?
Kellie is a paid member. So she'll be an active member in the club.
Congrats to all...
This is so excellent to see. Great Committee!! :)
Well Done to everyone involved with getting it off the ground and I am sure its only going to get bigger and better!
So excited for SA!!! Been a long time coming :woot:
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
