if you were goin into the housing.. i'd most likely go location 1, however better off in my opinion to put it in the intercooler pipe close to the turbo, saves having to pull apart the turbo than drill tap and clean and worry about possible little bits you "may" have missed
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4623553
location 1 would be better to reduce turbulence.
I have found boost control will be better if you tap a hole 20cm from the compressor outlet. usually on turbos with large compressor wheels and small compressor covers you get a lot of turbulance. not the case looking at that compressor cover but still if possible i say 20cm away from the turbo
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4623678
I suggest taking it from the inlet manifold so that when you shut the throttle it slams the waste gate shut... Will help you tremendously in getting it spooling properly in the next gear, and then your EBC if you go to run one, will be taking the pressure source, from the point most people have their boost gauges running from... :)
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4625761
i had mine running from there after i put my fmic on and i was having all sorts of boost spiking issues. moved it to the pipe from the turbo to the cooler and it held boost solid as a rock. the reason being that you end up with a longer hose so the pressure takes longer to get to the wastegate so the turbo will be creating more pressure than the wastegate is seeing for a short period of time.
also having it from before the intercooler means that if your cooler creates turbulence resulting in increased restriction above a certain pressure your turbo isn't going to be working harder than you think. ideally you should have your boost gauge before the intercooler as well. if your intercooler was crappy and added restriction of 2 or 3 psi at 13psi and you have your gauge and wastegate line after the intercooler then you only think your turbo is running at 13psi but it is really running at 15 or 16psi and shortening it's life.
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4625772
I don't have a single issue with running my pressure source from the manifold, and I know many people who do it also.
And I have a light switch turbo, in the fact it's nothing nothingn othing everything all at once. Doesn't spike one bit.
From down near the intercooler, I'd say is actually more hose then running straight across the firewall.
Also, I didn't think the waste gate allowed the air from the pressure source line to "vent" to atmosphere. Therefore, pressure along that line should always be the same no matter what.
Also, if your boost guage is T'd from before the cooler, how do you know how much boost you're running at the motor?
Like my car runs a map sensor, so if I take my boost reading before the FMIC, where the temperature is roughly going to be the same (Hence, at same pressure etc, same amount of air is there) but my FMIC is working a lot better as it's colder, suddenly my motor sees 2 PSI less then I want it too, the MAP sensor picks up on this, and will make the car run in a different load point on the MAP... Shortening the engines life... And hey, I know I'd rather replace a $2000 turbo then a $7000 - $10000 motor... Also, if you're running that high up near the top of where you should be running the turbo, that pushing one or two more PSI is going to damage it, then really, you need to rethink your logic of choice of turbo, and pressure you're running...
Also, are you saying your boost guage, you don't let it read into vacuum?
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4625811
Sory champ but why do lots(most) manafacturers all go from the cooler pipe or compressor housing? Cos its the proper spot to have it. The way yours is set up the boost controller will be working very hard to control boost. 1 thing I notice is how much nicer the turbo comes on when getting sourced from the cooler pipe/compressor housing.
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4626771
Mine comes on beautiful and strong. Set to come up to 14PSI, and it does that straight away, and not a single PSI over. EVER.
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4626959
what ecu do you run ? We will have to stay away from them if they cannot handle a 2psi change in boost
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4626968
The ECU can easily alter fuelling.
The difference being, when you tune a car to say 18PSi. with WOT, 16PSi at the same rev point, usually relates to a slightly closed throttle.
16PSi wot and 16 Psi partially closed are two different VEs on the motor. Not by much, but ever ever so slightly.
Also, MAD082 may want to share what turbo he runs an aftermarket one can't handle running 2PSi more then it is set for... :(
https://www.sau.com.au/forums/topic/272235-does-it-matter/#findComment-4626980
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
