I heard it's pointless, cos as soon as you put local fuels in it, you loose pwr and end up only similar pwr with local delivered ones... and you only have 180 speedo. But I heard the leather steering wheel looks nicer in jap version than the local plastic ones.
Why not start with local S15 and mod it up? at least you got warranty if u buy it new and local delivered ones usually holds its value better...
there is a slight difference. power being the 1st. the silvia badging,.... i think maybe injectors or something, wait for dark to dig it up. oh the reflectors in the rear bumber arent in the jdm and the years 1999 jdm later aus.
id personally buy a jdm spec r over an australian one.
sorry.. i cant find the site..
but its a webpage of someone on this forum, with a fully JDM converted white S15..
i remember, it had a popup dash monitor, and headlight washers, rear wiper.. stuff like that..
different tubro
electric fold mirror
crimate control
A pillar boost gauge
badge
rear wipers
180 speedo
silightly different head light
surprise, u pay less insurance for Jap import S15 than aus. S15 due to the accident rate
and u can have a Jap S15 for high 20' instead of low-mid 30" aus. spec
To summarise:
JDM > AUS
climate control
xenon hid headlights
tv screen/sat-nav/md
rear windscreen wiper
factory boost gauge/a-pillar
180km instrument cluster
fog lights
ignition keylight illumination
heaps more, see
http://www.bengoodger.com/cars/silvia/jsit...s/options.shtml
*tv screen/sat-nav/md
are option but not standard
i read a few aus. magazine when the car release, mention about smaller tubro in aus. spec due to esmissionyep only jap spec
s15s have BB turbos,
ozzy delivered s15s are non BB, but roll bearing turbos..
i GUESS there is no way a factory Jap S15 is tune for 100 octane, so the jap spec should preformace 184kw in aus. fuel
Originally posted by HKSgtst
i'd get a Jap spec one. As they are cheaper, more powerful and rarer.
But nowadays S15s are everywhere. oh yeah, its hard to find a good condition jap spec S15.
you'll make the savings buying a jap spec model, but you'll end up paying it all back or even more to insurance...
oz delivered s15 are heaps easier and cheaper to insure
not really
someone found out that Jap spec is CHEAPER to insure due to the accident rate of Aus. spec is so high.
It is cheaper to insure a Aus spec S15, Im sure of it having been on the silvia forums for awhile.:uh-huh:
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
