;) Oh dear, she said last night she may have been doing up to 30km/h over past the second camera!!! Here comes loss of license.....better put on my chauffer hat :D
In defence of her, the second road she got busted on has been 80km/h all of our life, and has only just gone to 50km/h recently.....but still, speeding is speeding. She's all good though, she'll take whatever comes and accept it with the right attitude :D
  • Replies 86
I still ROR at the silly bitch in the white Evo 6 busted twice in 400m a few months back :D
First by a speed camera near the old Adelaide gaol, because she wanted to race me, then near Maccas when she weaved thru traffic and raced past an unmarked motorcycle cop (despite it being very bloody obvious it was a cop!). Hope she lost her licence. Hoon. ;)
2 years ago I got nicked by a Vic cop in the country for doing 83 in an 80 zone, and just 100m from entering a 100 zone, after passing thru a country town. Anal or what? :D
3 demerit points too!!! 1 for each 1kph over!!! He gave me the whole speech to about "I don't know what you south australians think you can get away with, but we don't tolerate speeding". My reply was like "If you were working in SA, and if you let 3kph upset you, you'd be in for a shock".
cant you argue ur speedo is out? as if anyones dial is that accurate. my damn dato was 10k's out, its pretty reasonable to think an average car would atleast be a couple of k's out at that speed
Edited by Inline 6
^ you could argue that yes, but they sound so fking anal about it they'd probably defect you for the speedo being out as well.
Oh dear, she said last night she may have been doing up to 30km/h over past the second camera!!! Here comes loss of license.....better put on my chauffer hat :D:mad:
In defence of her, the second road she got busted on has been 80km/h all of our life, and has only just gone to 50km/h recently.....but still, speeding is speeding. She's all good though, she'll take whatever comes and accept it with the right attitude :P
By that last part I assume you mean she has agree'd to let you put it in her ass as retribution for racking up bulk fines?
lol. take it like a trooper?
i was thinking the exact same thing eh.
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
