BRAND NEW Hypertune 90mm Plenum AND Hypertune Throttle Body $2300
Reason for sale: Upgraded to 100mm version
Will post interstate to capital cities at my expense
contact: Trent 0402 421 437
Edited by MercuryMotorsport
https://www.sau.com.au/forums/topic/272250-hypertune-rb26-plenum-tb/
FROM HYPERTUNE WEBSITE
Intake Manifolds:
DESIGN
The design process begins by assessing the original vehicle and engine characteristics, as a guideline for the products development. Considering our customers requirements and installation limitations, parts are designed and analysed using advanced computer software to produce prototypes for testing purposes.
The characteristics of the intake manifold are developed to increase overall efficiency, particularly in the mid and high RPM range, whilst minimising detrimental effect on low RPM response. Consideration is made for modified engines (camshafts, turbochargers, etc.) to assure the products performance and suitability for high output applications.
Initial designs are sent to our highly experienced distributors worldwide, for testing and refinement. Once the design has been perfected, manufacture of the production parts begins.
MANUFACTURE
Hypertune Intake Manifolds are manufactured using state of the art CNC machinery, and metal forming techniques developed in-house.
The goals of the manufacturing process are:
+ faithfully represent the CAD designed and developed parts
+ produce a high quality, structurally sound and reliable product
+ maintain the fit and appearance expected of a class leading product
To maintain accuracy of critical dimensions, the entire intake runner is CNC machined to accuracy within .005mm. This tolerance is well beyond the capabilities of most porting services, and guarantees that your intake manifold will be suited to the best prepared cylinder heads.
Although this process is very time consuming and expensive, we believe it is the only way to achieve perfection on a part that is critical to the performance of the intake system, and often difficult to prepare by hand. Plenum chambers are produced using a unique hydroforming process, developed in house. This allows us to produce a light weight, structurally sound part, with smooth surfaces for maximum flow potential and good appearance.
The manifolds are finally welded and assembled by true craftsman, who pride themselves on producing some of the highest quality and most unique products in the industry.
Throttle Bodies:
Hypertune are proud to announce the availability of our new range of universal throttle bodies.
The project began in response to our customers' requests for a throttle body worthy of the quality and performance of our range of intake manifolds. Our aim was to provide the best possible combination of performance, appearance, reliability and ease of implementation. Have a look at our list of features and we are sure you will agree, we have achieved our objective! CNC machined 6061T6 billet aluminium body section provides the best combination of strength, accuracy, light weight and appearance. Diameters have been chosen based on commonly available hose sizes and a large bead is provided to assure positive retention of the hose under boosted applications. Body section is clear anodized to further improve longevity and wear resistance.
+ 10mm diameter slotted steel shaft combined with 2mm thick brass butterfly provides high resistance to bending in supercharged / turbocharged applications. Shaft is blackened for corrosion resistance and improved appearance. Butterfly is machined in an elliptical shape with 7 degree taper to perfectly fit the throttle bore improving sealing and resistance to binding common with many other designs.
+ Dual sealed ball bearings securely locate the shaft/butterfly eliminating the shaft float and subsequent wear common with many other designs. Ball bearings also provide very smooth action and vastly improved sealing and service life compared to bushes.
+ Unique indexable pulley allows adjustment of cable position to suit any application. M5 threaded holes around perimeter are provided to assist with addition of extra return spring or linkages for multiple throttles where required.
+ Throttle body can be ordered with clockwise or counter-clockwise rotation. This choice can be made based on TPS rotation or installation requirements.
+ Various TPS adapters are available that allow direct bolt-on of most common factory TPS sensors. This unique addition simplifies installation, eliminating the need to purchase another TPS and adapt it to your engine.
+ Custom-made stainless steel spring provides smooth, linear action and positive return. Spring is contained within stopper barrel section protecting it from foreign objects and improve appearance.
From conception to final assembly, the Hypertune throttle body is designed with quality and performance in mind. Only the best techniques and materials are combined with state of the art design and machining practices to produce what is the new industry standard in universal application billet throttle bodies.
