I don't understand how Titanium can crack..?
It is one of the worlds strongest metals...
I think they mean the type of exhaust setup... Most track cars may use Full Titanium exhaust (Cannon mufflers) like HKS for example and Titanium is very light to save weight.
Some of the aftermarket Oval Shape mufflers my use Stainless Steel.
Do they apparently after listening to a lot of heardsay. Its when they gets really hot and a stone or something hits it (chances of a gravel or stone hitting the car is much higher than on track). But someone told before as well... its really all luck dependent. How often do they get THAT hot? Unless you're flooring it all the time for a roadtrip?
If you like titanium and got the money, go for it (they sound awesome). But none of them are of legal dB limits (not THAT bad as well). I've decided to keep mine and spend the extra money replacing my rims.
That's understandable.
You got a point there.
But like you said, Titanium exhaust for street, how often will it get that hot just for normal street driving...
Chances are next to nothing IMO.
Well the one I was looking at is a full titanium system (not just muffler & no cat, i know)..
Safe/unsafe? ;)
As long as you can keep the dB levels to legal then you are fine.
Okay thanks for the info. As I remember it sounded really deep and lumpy.. mhmm.
I'm not going to bid on that one though. I was only interested because he stated it as titanium. Rather get one in perth and save the postage money. Theres one at Jap Performance Centre in Osborne park - custom made one for a R33 GTR (full stainless, includes cat) that i'll probably buy unless something else nice comes up.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=180362733632
Edited by Ten Four
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
