U could try hollowing out the cat and inserting a pipe through the cat. Benefits of this are:
1. The original cat is still in place.
2. If u tap the cat it wont sound hollow, since there is still some cat material left in it.
3. U get the performance of a straight through pipe...plus the flames to boot (i love the flames the most, although the performance increase is not much)
i dont know if its different for na's and turbos but when i did i got a very noticeable increase in power and the flames!!! but then i got the shits cause it made the resonance in my exaust 10 times louder so i got a new one. the fine for having a cat that doesnt work is 200 bucks the fine for having no cat at all is 2000 bucks, take ur pick.
In NSW it is 10,000 if you're caught, details are on the EPA sight, search for catalytic converter.
Of course, how you would get caught is a different matter, presumably you would have time to rectify it before being tested....
It just seems crazy to me, risking a fine that big for marginal gain.
If you run a straight pipe through the centre of your cat no one will know.
But there will be no measurable performance difference, there might be a bit more noise, and there will be more black crap at the back of your car which will discolour the paintwork and bumper.
If your cat has disintegrated and is rattling or blocking the pipe, get it replaced.
My mate had this done to his CA18DET powered car, before this happened i would pull away in top end quite a bit! Now though they are even up top, with no changes to management or anything, either car!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
